Phasemation T-2000 - introduction to my favorite Step - Up
XV-1
3,620
2,629
1,860
Sydney
Well the T-2000 is not going back to the dealer.
It works very well with both the Lyra Atlas Lambda SL and the Phasemation PP-2000. I will try with the Ortofon A90 in the near future as that will sound pretty cool.
Both carts sound wonderful with the EA-1200 so probably every month or so I will swap the cart feeding the T-2000 / EA-1200 MM.
It's a good option to have as the T-1000 SUT inside the EA-1200 are wonderful in their own right and a very easy plug n play.
Time now to enjoy the music.
XV-1
3,620
2,629
1,860
Sydney
The T-2000 is the best SUT I have ever had in my system. I just ordered a second pair that I hope receiving within two weeks.
Your EA-1200 with the two power supplies and the T-2000 should be close to the EA-2000.
congrats, the 2nd T-2000 will be awesome.
the 2nd power supply for the EA-1200 took it from a very good phono to a special phono - I was quite amazed at the difference.
shakti
1,444
2,412
480
Cologne, Germany
Gents, @XV-1 & @shakti, how does the T1000 compare to the T2000? T2000 head and shoulders better?
T-2000 is the better step up!
...but:
T-1000 has a very little different tonal balance compared to T-2000,
T-1000 is more lean and clean,
T-2000 has more weight and substance.
One of my friends, using EA-550 phono stage, preferred T-1000 over T-2000 in his set up (koetsu cartridge)
XV-1
3,620
2,629
1,860
Sydney
Reactions: Johan K
raduchelaru
2
51
Bucharest, Romania
Hi Shakti
Only ever had phono stage's with rca input prior to Phasemation. not had a chance to try XLR yet. EA-1200 is silent with rca tonearm cable.
No nore hum - fixed.
The D'Agostino HD preamp power supply was too close to the T-2000. I moved it down to the bottom shelf and noise gone!!. See pics SUT'S are very sensitive things.
thanks Shakti
hi, a saw an Accuphase C37 on the shelve and wonder how it compare to Phasemation EA550+T1000 which I have in my system. I am tempted to go for Accu C47 to replace Phasemation combo. You have the experience I think. Thank you.
shakti
1,444
2,412
480
Cologne, Germany
I compared recently C47 and EA-1200 and preferred EA-1200 for a better flow and a more easy access to the heart of the music as such. Specially when connected to a second PS-1200 power supply, the EA-1200 is difficult to beat.
An friend made the move from EA-550 / T-1000 combo to EA-1200 and to our surprise still uses T-1000 as the main step up and prefers this over the internal step ups.
Reactions: Dane33
raduchelaru
2
51
Bucharest, Romania
thank you, I have noticed the step up T1000 is magic and improve any phonostage, i have tried it with leben eq30 also and push the sound to a superior level.
