Phasemation PP-2000
My headshell is the CS-1000 as I got it before the new one came out. I'm pretty happy with the PP-2000 and could easily live with it as my only cartridge. What you wrote above is my opinion as well: "relaxed, sophisticated almost sensual." It doesn't sound sluggish or undynamic at all, so those traits are really special.
Reactions: XV-1
I think the CS-1200 headshell is the same as the CS-1000 except the headshell leads, which are now the new triple C cable Phasemation are using.
Cheers
I have put about 40 hours on the PP-2000 and been playing it all week.
Wonderful musical cart and seems to he able to play any musical genre I have thrown it so far.
Sounds pretty amazing on Jazz and Jazz vocals which was expected. It is really sounding good on electronic music which I was not sure how it would fare and imdie rock is being handled easily.
Sound wise it has seemed to have settled down - maybe it might change up to 70 hours a little more
I will probably look at getting the Phasemation CS-1200 headshell like Ed P, which is a little lighter than my old CS-1.
Hello XV-1,
You have so many cartridges..If you have done a match, which prefer you, please ?
I will try perhaps a PP-1000.
You have Lyra Atlas Lambda SL, Etna SL, Delos, Dynavector XV-1s, Technics EPC100mk4, Ortofon A90, GM Royal, GM Classic, Denon DL-S1, ESC'd 103R, Audio Tech AT25, OC9II, Linn ESC'd Troika..
I don't like Ortofon A90, I llike AT-OC9ML III ( I don't know the OC9 ML II ).
For the moment, I have two Audio-Technica ART-9 (I think I will sell them) and ZYX 4D (Beautifull cartridge).
Thanks
Reactions: dan31
Hello XV-1,
Thanks
Thanks. All excellent carts in their own right and all have different sonic traits.
Perhaps the best cart of all is the Technics EPC100mk4, however the suspension is a little soft now after 40 years and virtually too hard to bring back to original factory spec.
My fav is the Lyra Atlas. I have been thru all variations and it's still the quickest and most linear cart of them all.
Thank you very much.
Art-9 matches well with my VPI.
Art-9 doesn't match good with my Technics. I have the sound of a CD player with this turntable....very funny...
I prefer the ZYX with it.
Reactions: XV-1
