Playback Designs MPD-8
First glimpse
The additional xlr and rca analogue inputs at the back
Innards of the new A.i version
First glimpse
Would be interested to hear your thoughts on the Pink Faun + Playback combination
Just received the latest MPD-8 with upgraded analog output stage, very happy camper. Have a DAC that is twice the price in the house and I prefer the Playback.
First is the analogue stage, which will get an all new circuit design. This is due to certain components in the current analogue stage going to be out of production soon. PBD is taking this opportunity to change/improve the analogue stage.
Secondly, PBD will add 2 analogue inputs into the MPD-8, which then will be renamed MPD-8AI. One set of XLR and one RCA input will be added.
From the PBD website it looks like only the second change you described happened and that the circuits are identical between the original MPD-8 and the new AI version.
Does anyone know the cost to upgrade an older version to the newer?
looks like Andreas caught us by surprise, and except for the add of the extra analogue inputs, he didn't do nuthin' to improve the dac's output circuits at all. dCS and Emmylabby be damned. PB's analogue output are already optimized. more tinkering will only makes the sound worse! so there, haha! so for anyone not requiring the extra analogue inputs to be mounted on the dac, and will continue to use their pre-amps in resident, there is no need to "upgrade to" the A.i version at all.
around the last week of Oct, i will head up north to attend the hifi show in kuala lumpur, where the newly appointed dealer for PB will be exhibiting the pink faun + the mpd-ai combination. in between will be the usb-x4.
my mps-8 took more than 800 hours (via a streamer) to sound "acceptable".
Does the EMM NS1 source work with MPD8 over plink?
Reactions: Ian B
I doubt it but I'm not 100% sure.
I can say that the Nagra streamer works with the MPD-8 over Plink and it is exceptional, particularly if you have a classic PSU for the streamer.
I did try the EMM NS1 with a Nagra dac and it did not work over plink, so I assume the same is true for the MPD8 (in other words Nagra link and Plink are the same thing).
Reactions: shawnf and orrman
If your source for the MPD8 is an Eversolo...there is only so much the MPD8 can do, even if you're using the USB-X4 interface.
Reactions: F208Frank
the dmp-a8 was merely a tool to run up the number of hours on the internal clock counter.
the mps-8 plays cds and sacds
Hi, Was this confirmed by PD? no difference other than the extra analogue inputs? Thx.
Andreas confirmed there are minor updates because older components were discontinued and some tweaks he had in mind since the original design (and that also required a few software changes) but new and old MPD8s should perform similarly .
Reactions: tonypdb
Curious what power cables owners of the MPD-8 have experimented with. Ultimately it's a subjective journey, but it is interesting to read about. Also, any MPD-8 users out there running a Lumin U2/ with USB-X4 or direct (AES, USB etc)?
I put an order in for an MPD-8 and have a Lumin U2 that I like very much. Was planning on the X4 in the near future. Thanks in advance.
I use the shunyata alpha v2 NR.
For this line the XC is recommended for power amps that are A or AB. NR for digital components.
But for the newest line, alpha X, its reccomended to just go all NR for both digital components and amps.
Bit confusing yes. Call Shunyata for extra clarification. This was what was told to me by Shunyata direct.
Mpsx makes such a nice difference I feel with the MPD8.
At the least get the usb convertor, the benefits of mpsx is that it also has a linear power supply along with the streaming function. Since I use antipodes, I do not use the streaming function part of the mpsx which does feel a bit wasteful.
But I wanted to experiment with oladra streamer section vs mpsx streamer function on my own terms and take my sweet time.
Reactions: audiopacer and PYP
Has anyone compared the Emm Labs DV2i with the MPD-8? Would also be curious to know which of the two has a better volume control as one is digital and the other is analog.
Reactions: chrisyak
Here are my notes when I compared both at home, MPD8 was my own DAC and DV2i was a friend's that he brought over.
  • Very minor difference overall, both sound excellent
  • MPD has a little less mid bass presence so less bloomy, comes off a little cleaner
  • Treble clarity higher in guitars (noticable with texture details)
  • MPD8 wins on vocal realness with a slight margin, just feels a bit more natural
  • Vocals are a bit more forward closer to listener with DA2i
  • Vertical placement of instruments was a bit more closer on DA2i, can't decide if that's a good thing
Overall I preferred the MPD8. Didn't compare the preamp.
I love the MPD8, truly. Was comparing with another DAC recently and made me appreciate MPD8 even more.
Has anyone heard both MPD-8’s (old vs new output stages? If so, how do they compare? Thank you.
