Guys I will most likely be upgrading from FM 801A to the PB SPA-8 , to make the synergy whole since i am 1/2 way there.
I would love to hear this! Congrats!I have had the MPD-8 in my system for a little over a thousand hours. It replaced a Totaldac D-1 Dual with Totaldac Reclocker. It is an expansion on all the qualities of the Totaldac--open, alive, natural, musical--with a more extended top end, a deeper and slightly wider soundstage and better mid and low bass, both in definition and extension. It also reveals considerably more detail which is never in your face or unnatural. I drive it with an Antipodes DX going by USB into the Playback Designs optical converter that connects to the MPD-8 through its proprietary "Plink" link. The DAC goes straight to my Enleum 23R driving Cube Audio Nenuphars. It is a beautifully made and sounding piece of gear, one that I consider a permanent part of my system.
I would very much like to hear that, should be great. If I were looking for a new amp to go with the MPT-8/MPD-8, it would be between the SPA-8 or the Boulder 3060. I have the Pinot ADC, so could run analog in a Playback Designs system.Guys I will most likely be upgrading from FM 801A to the PB SPA-8 , to make the synergy whole since i am 1/2 way there.
Very interesting system - nice!I would very much like to hear that, should be great. If I were looking for a new amp to go with the MPT-8/MPD-8, it would be between the SPA-8 or the Boulder 3060. I have the Pinot ADC, so could run analog in a Playback Designs system.
Bro , I recently got my SPA8 amp and it is simply crazy and magical sounds ! you have to get one !I would very much like to hear that, should be great. If I were looking for a new amp to go with the MPT-8/MPD-8, it would be between the SPA-8 or the Boulder 3060. I have the Pinot ADC, so could run analog in a Playback Designs system.
I just got mine one done as well ( but apparently I have been on the 019 for a while, so when I tried to update it , it actually went back to 018, but I was able to get it back to 019, and I also did the X2 unapt as well on the MPT8, ) I find that even I am using K50 , I much prefer to use the MPT8 as my streamer connected via ethernet from the K50, and prefer that over AES or USB from K50The new 019 firmware update for the MPD-8 is a big sonic improvement. Highly recommended!
I currently use Direct stream from K50 to MPT8 then Plink to MPD8,, I much prefer that over the USB from K50 for sure. I gotta give AES another go.Christiaan Punter recently did reviews on Playback Designs MPS-X and then MPD-6. He tried an interesting experiment in his review of the MPD-6 inserting the MPS-X between his K50 and MPD-6 using AES/EBU from K50 and PLINK from MPS-X to the MPD-6. He was quite taken with sound quality improvement he perceived.
If you use stand alone PBD streamer and take K50 out of chain completely with your PBD DAC, does it single handedly beat the K50?I just got mine one done as well ( but apparently I have been on the 019 for a while, so when I tried to update it , it actually went back to 018, but I was able to get it back to 019, and I also did the X2 unapt as well on the MPT8, ) I find that even I am using K50 , I much prefer to use the MPT8 as my streamer connected via ethernet from the K50, and prefer that over AES or USB from K50
Having fiber for the 8 Meter connection between the Stream-IF and MPS-5 allowing me to use 2 Meter XLR interconnects is a stunning improvement in anyway you can imagine.That is interesting speakerlust.
I am changing the location of my Pre-Amp and MPS-5 to the front of the room rather than at the side wall by my listening chair.
This is to eliminate an 8 Meter interconnect. I am keeping my Stream-IF on the side with some other front end equipment and running PLINK between the 2. I'm curious as to the sound as I think it will be better than the OCC DIY cable I have been using. The thought of spending $1000's again, or try a TrippLite 10 M fiber for $34. That is a no brainer. I will know next week. Then you will know.
Can you say how to do with a MPT-8 SACD Transport ? ... I am interested !Yes. It works.
Hello Chuck,I would very much like to hear that, should be great. If I were looking for a new amp to go with the MPT-8/MPD-8, it would be between the SPA-8 or the Boulder 3060. I have the Pinot ADC, so could run analog in a Playback Designs system.
