No need to apologize Theo, not a big deal![]()
Actually IIRC Barry was using a marble tile as the upper race at some point.
The problem I see with a direct supporting of the component (through racing plates) is that there is no direct control over the damping
of the upper races. And IMHO this is absolutely *critical* with the roller bearings.
Not sure if it proves anything, but not a single time we heard
the typical for suboptimal bearings comment of HF harshness or artificial vividness. Never!
To the opposite actually. People used to artificial and harsh HF in their systems,
first find something lacking with our platform in action.
Cheers,
Jarek,
My impression is that should the underside of the component not be conducive to the ball pressing into it, then the 'tile' or another material could be used. This is the case with my GT 2000. The plinth of the GT 2000 is multi-layered MDF(HDF?). I didn't feel that having the Silicon Nitride ball in direct contact with it was the optimum for free motion of the ball. I went to a local metal fabricator and got them to cut two small panels of 5mm stainless steel which fit nicely into the undersides of the turntable.
My turntable support/isolation platform remains a 'work in progress'. The only guaranteed long term elements, at this stage will be the Clearaudio Magix and the Ingress balls and cups. All else is ultimately due to be replaced by some other element. The polymethylmethacrylate which is directly atop the Magix( sorry I left the 'poly' off before) I will replace with either Carbon Fiber or a sandwich of kevlar honeycomb between two sheets of carbon fiber. I'm still weighing up which way I want to go.
Unlike yourself Jarek. I have zero background in Science. I left school at 16. I tend to the intuitive style of research. Grossly unscientific, but it is my nature and it works for me. I have a respect for science, but it should never be forgotten that a slew of breakthroughs in Science came about via the scientist having a Eureka Moment which set them off on a tangent which was a cross-purposes to the investigation they were previously undertaking. A path that they never before considered. That, and taking notice of other people's ideas is how I operate.
I can say that the pay-off for me has been a transformation of the sound of my system(which is as my signature attests vinyl-based). Two of the longest owned records in my system are the Opus 3 Test Record 1 and Proprius label Cantate Domino. I used to take them with me to dealerships over many years to audition systems. It was incredibly gratifying that after further fine tuning of my isolation support the other night, to hear both of those records reproduced in such a manner as I had never heard them before. The gratification was repeated on other great recordings.
I have been consumed by turntable isolation for the almost decade since purchasing my original 8 Clearaudio Magix. The achievement the other night made it all worthwhile. I have about 3500+ LPs which will all benefit from this. Some to a greater extent than the others, but all will sound better than the previous time I listened to them. I cannot emphasis enough that if one owns a well-sorted system, properly isolating at least the Source component will give an astonishing boost to the musical and sonic enjoyment.
