Can someone please link the specific product numbers or name for Deoxit, Flitz, and Kontak? looking at the various versions and I want to be sure I get the right ones. Thank you.
I don't use Kontak but use
Caig deoxit D5 for non precious metal https://www.partsconnexion.com/CAIG-67190.html
Caig deoxit gold for precious metal https://www.partsconnexion.com/CAIG-67194.html
You must use these Caig product very sparingly!
Flitz for AC power blades polishing only https://www.flitz.com/flitz-polish-paste/
Fiberglass pencil for tube pins https://www.cooltools.us/Scratch-Brush-Pen-Style-Fiberglass-p/brn-207.htm
Yamaha made in Japan polishing cloth for pins ( this is highly effective- only this type):
https://reverb.com/ca/item/35253920...Vx2T4XBMTDw5tPUwNxDFC4sZLXi6oxMxoC8yEQAvD_BwE
After cleaning tube pins with fiberglass pencil and or polishing cloth you must clean the pin/ connectors with 99% isopropyl alcohol.
Cleaning is just not for tube pins but for RCA connectors and XLR connectors inside and out. I use slender cotton swabs to get into IEC and RCA/XLR female jacks. Small pipe cleaners as well.
I do not spray or use any contact enhancers on tube sockets.. I only clean them with 99% isopropyl alcohol.
