He spends all his money on Duelund an Hõrning components.![]()
He is mostly just cleaning his solder like below and Kedar is trying to drop in
A playboy friend of mine in Miami always says " if it floats, flies or f...s, rent don't buy" !get a boat and you´ll understand the expression "boat money" and "sunk cost"
Like the LP you mean?Weird design. I would not want to constantly be removing and replacing it.
A requirement if you want to listen to a record. I would compare it more to a record weight/clamp. There’s just no reason to have it sitting over the spindle though since other options work perfectly fine with less hassle. I would be surprised if people on WBF want a plastic record weight.But you do ;
constantly remove and replace
You imply it’s left as plastic record weight during playback which is not true. You distort the facts about its functionA requirement if you want to listen to a record. I would compare it more to a record weight/clamp. There’s just no reason to have it sitting over the spindle though since other options work perfectly fine with less hassle. I would be surprised if people on WBF want a plastic record weight.
Wow I watched the video it’s even worse than I imagined.You imply it’s left as plastic record weight during playback which is not true. You distort the facts about its function
We all judge products on this forum, including you.Why be such an ass?! Just don’t buy it
Not a fan of that design at all but I’ve had success using the IME1 and Westek. To me it doesn’t make any sense design wise, just an opinion. Not everyone has to agree with what you like, bonzo75 is rubbing off on you.we understand you think it´s impractical and maybe even stupid, but why rub it in?
When I recently acquired a TT I realized quickly I needed to do something to mitigate the static on the vinyl. Have lots of experience with the ZeroStat but never thought it worked very consistently. Both the CSPort IME1 and DS Audio ION-001 Vinyl Ionizer were under consideration but I hesitated with adding another essentially "always on" device to the system plus I have an aversion to distracting lights (not a big deal but something I wanted to avoid if possible).My CSPort IME1 arrives next week. After a lot of reading and research it's the one I decided to go with. Steve at Sounds of Silence is an absolute pleasure to deal with. Here in SoCal the Santa Ana winds make static a nightmare.
