I don't understand the question either. I listen to the Vyger, the brinkmann, and a 124 frequently and hear surface noise when present separately from music. But I still do not understand the question or what different things I am supposed to hear
Interesting observation from you Shakti. I never really paid attention to notice the different surface noises from different platters. Could be so like you said especially from vacuum hold down vs. non vacuum. The surface noise I find is also influenced by cart. Please let me know if I am confused with something else but for example I find the Opus1 run quieter than the Master Sig. on the same vinyl. The same groove noise and click pop are more pronounced with the Master Sig. Too bad I already took SAT out of my AS2000 other wise I could do a test on the different platter of AF1 and AS2000.On my different turntables (not the league of Tang's collection) I can hear different surface noise. I prefer the "sound of surface noise" on vacuum platters, preferable with guns metal platters, as with Micro Seiki or TechDAS. The surface noice gets more dark. On my other turntables the surface noise is with more energy in the middle of the spectrum, may be more close to the resonance of the vinyl as such.
The surface noice on my TechDAS AF3P is from that perspective less prominent and less interfering with the music as such.
But I like say, this is just my personal taste.
It could be possible (and I strongly believe this) that with better tables (like with Tang) the difference becomes minor.
I can’t for the life of me hear this surface noise you’re talking about. Am I missing something
You are lucky to have the Aqua space shuttle transport you out of this world...to the pitch dark space Blue.I can’t for the life of me hear this surface noise you’re talking about. Am I missing something
I do use only SME headshell on all my 3012R arms. I go through alignment process again when changing cart. I dont play around with head shell because I am already happy with the sound I get from the original one. I also have quite a few types of screws but I dont screw around . I use whatever screws that come with the cart.Tang, do you use SME headshells on all your 3012R arms? I am referring to the ones where the cartridge location isn’t adjustable.
If so, when you change headshells/cartridges do you go through the alignment process again? Just curious since I have a 3012R arm as well.
Maybe you don’t have to do this since you have 4 arms!
Kind regards,
Tang
I did XV. I was using it with GFS on one of my 3012R. I did not think there was anything better. Dietrich is one designer who met me quite often but never pushed me to anything or try to convince me that his equipments are better. He is more of an engineer and likes to talk about technical stuff. He could impress the hell out of Micro if they talk.Tang, I would have thought Dietrich would have tried to get you to use his headshell on the 3102R. It is something you should try for your own curiosity and ours
(...) He is more of an engineer and likes to talk about technical stuff. He could impress the hell out of Micro if they talk.
Tang
