Do you guys plug your amps in the Torus. A friend just got a Stromtank. He was told not to put his Dagostino M400 amps through it. Amps direct to wall. All front end gear through the Stromtank.
Can you share your opinions (+/-) of having the Mephisto plugged into the Torus?Yes, we plug our Gryphon Mephisto into the Torus AVR16. However, I should note that we did NOT do this until AFTER emailing and speaking directly with the designers of BOTH Gryphon and Torus with the specs of each piece of equipment. Both confirmed they were happy for us to try, and we did.
HI Forte,Can you share your opinions (+/-) of having the Mephisto plugged into the Torus?
the only AC power conditioner that doesn't kill the sound or diminish the energy of amplifiers is Synergistic Research new UEF line..
definitely but I did tested a lot including gigawatt.By "The Only" I assume you mean only the SR out of the ones you actually tried.
Furman Reference 20i, use the high current outputs, and you are done. Drove my 400-watt McIntosh amp with no problems in fact it sounds. Stay away from balanced designs they work OK for front end gear, but for all the ones I've tried they thin the sound out, and some gear does not like a balanced current. If anything you could go with a PS Audio regenerator, I used P-10 would be a great option, but for amps, I still get a Furman.
The High Current outlets are Linear Conditioning. The others are semantically balanced for low-level gear from streamer and anything else that does not have a need for high current voltage needs, this totally isolates the amps needs from effecting low-level gear, each of those banks is totally isolated from the other. The unit has a huge Isolated transformer and weighs a ton.I don't quite understand this statement as the Furman is a balanced power device.
Did you get the Ypsilon SET 100 Monos in as per your signature block? How are they?shunyata everest mate! it doesnt limit the amps
That's what the 6Moons review said about the Bybee Stealth Power Purifier which is what I use:By "The Only" I assume you mean only the SR out of the ones you actually tried.
