I totally agree.I find that that’s the Torus/Bryston BIT are underrated gems. They go about doing their job without hue and cry. And they don’t cost an arm and a leg.
Already done! Yes...agree with that. I am using my Gryphon VIP Ref Cable which is 20amp in lieu of stock. The once additional difference however is that it plugs into a dedicated 20amp outlet...whereas the stock cable is for a standard 13 amp outlet. So by changing cables, i have actually made 2 changes.I am glad that you liked it. You will experience a greater improvement if you will change the factory power supply cable.
Most power conditioners suck the dynamic life out of amplifiers. Anyone find a power distributor that works great with high-current amplifiers?
Straight to the wall is always best for power amplifiers ..
Really?You would need about 800% capacity of an AC KIT actual draw to negate hysterisis...anyway.
I would guess out of 10 million audiophiles less than 50 have applied their stuff correctly .. If even that.
So basically no one...
So ....
No. Not even the manufacturers of their own gear even touch their own theoretical usage...
I am told the best high end system in existance is owned by Putin, Vladimir...
It value is unknown because it is fully custom...
Meaning that every and all components exist in one and only one physical product...
I really liked what AQ Niagara 5000 and IsoTek Sigmas are doing with amps. I didn't find them to limit the dynamics of my BAT VK-655SE! Highly recommended!
3. MUST ground this unit and the amp...that was a big plus in creating organic nuance to the music. I had to disconnect 2 Entreq Receivus'...and use the cable to ground the Torus and Gryphon...absolutely worth doing.
Hi GeorgeK,
Great insight. To make sure I am clear, you are running wall straight into Torus AVR16...and then the Gryphon Evo and Torus Tot (for sources) are both plugged into the Torus AVR16?
Interesting, as I think Aussienuet does the same with his AVR16 (and PS Audio for sources)...and I am also doing same with AVR16 and Burmester 948 (again, for sources only and going straight into AVR16).
I agree but this is easy to achieve in most cases.You would need about 800% capacity of an AC KIT actual draw to negate hysterisis...anyway.
So ....
Hi GeorgeK,
Hi...nothing too special. It worked, and I did not seek to optimize. Both of the units are connected to the Tripoint Troy. I am aware of the fact that some find the science behind it makes 0 sense. All I can say is that (for some odd reason) listening to complex choral music, I can understand certain words better with Troy connected than when it is not connected...no idea why, but that seems like a half-decent test for a non-techie like me. So I have left it that way.Please let me know what is your grounding scheme?
you ground the amplifier to the Torus?
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
