I fiddled with the setup and took more measurements.
With my phone db app, at normal listening volumes with either the 845 or the Dartzeel, my peek volume at my chair, about 7 feet from speaker hit 76 db.
On average, the high points of music were between 55 db and 65 db.
My ampacity meter set to .000 measured peak ampacity from a speaker cable as .12 amps on the woofer and .067 on the mid/horn. I am not breaking 1/5 of a watt total at my prefered listening level.
I moved my speakers. This had a large affect. The amps are so different in totality, a speaker adjustment was necessary. This brought a much better balance to the sound. More even and less beaming.
I changed a driver tube. Also a pleasant change. A tad more smooth with less glass sound.
The 845 is an Elrog.
I analyzed source more closely what am I feeding as a signal.
I don't want to start a pissing match, but here are some impressions.
The source is critical. My digital on a whole is more lean than my vinyl. I can play the vinyl a lot longer than the digital.
Either source I am highly aware the quality of the recording with the 845. If its not excellent, it's annoying.
Here is the fighting words. The 845 is head and shoulders, way past the Dartzeel when it comes to instruments being real and believable. I am gobsmacked and shocked at what I hear. So much so, I could only handle the Dartzeel for 15 minutes or so and I wanted it out of my system.
Yet the persistent (something) continues to exist with the 845. I was sitting last night with the music very low. About 45 db. Maybe a 50 db peak. I had a wav digital file on my harddrive of a decent recoding I like in the background. After about 10 minutes the sound was agitating me and I had to get up and click my preamp 3 notch down. I think that is 2.25db. WTF.
I honestly don't know if its distortion or something else. I don't know why this would happen, but maybe the timing is smeared. While very clear with amazing decay, I almost struggle a little to decider what I hear. And frequency peaks. I was shocked how much speaker placement influenced the sound. I have read serious pissing match here that an amp when reviewed should never be accompanied by speaker repositioning. Well, I'm her to tell you, these 2 amps like the speakers in different locations.
My next task would be to try a Umik 1 mic and measure the frequency response. I may have some steep peaks in the top end. The playback strikes me as hard, a little glassy, very dynamic. Probably tilted up in frequency response.
My thread was around how loud I can play with the Dartzeel. My prefered db is about 55 to 65 db average with peaks to 76 db. When I had guests over or get worked into a mood, I am pushing the Dartzeel to peaks I assume in the 80s. I didn't try this yraterday, but I have played plenty about 5 clicks higher on my preamp which are 3/4 db per click. So 3.75 db higher.
