Thanks, for sharing, Tom. Interesting, congrats for the system’s scheme!Hello and good evening to you, Luca. If I may, please let me present you with what I have done. 2 moats and Wi-Fi. The reason I am offering this is just an FYI. IMO/IME, Wi-Fi is not as bad as folks make it out to be. It is an additional moat, and if done correctly? Will yield VERY similar results from that of an Esoteric transport, Mutec REF 10 SE 120, fine cabling in between with both that of my streaming rig and physical music.
The two are VERY hard to tell between each other and some aspects are better on physical versus streaming and vice versa.....on my rig, it really boils down to the music itself. The recording. Mic placement and mastering as to which one is better.
With that said, this was back in February of this year and the entire rig has had upgrades, as well as the streaming rig but it was close to this point that it really didn't matter. Introducing Wi-Fi into a rig's room can and will offer you 1- phone coverage via VOIP. 2 - IME/IMO No degradation to the sound....in fact, an improvement. It's just another layer (moat) to reduce noise. YMMV, as all systems are dependent on a myriad of issues that are completely isolated and system dependent.
Tom
No worries, your setup effectively demonstrates how Wi-Fi is used between a router and wifi-satellite, though many of us rely on Ethernet or fiber connections directly to an eR (or another switch). In setups like yours, the placement of these devices is crucial to avoid cross-contamination and unwanted vibration, which could significantly improve sound quality. This also highlights that the performance of "the best audiophile switch" cannot be evaluated in isolation; it must be considered as part of the entire network configuration. A high-performing switch may excel on its own, but it is still just one element in a larger network chain before reaching the streamer/dac, and not a complete solution.Man, I really need to update this...
Tom
FritzBox is the best option to choose for the ISP router/modem. There are newer models from AVM/Fritzbox that might also fit your needs.You are right about the router but I’m using the one provided by the ISP and haven’t found yet an alternative able to sport the same input fiber port compliant with ISP specs (GPON). It’s a FritzBox! 5530, fed by a Sean Jacobs PSU DC3. Still looking for a better choice, highly appreciated any recommendations.
Excellent point, but quoted from the website mentioned above please consider the following points:FritzBox is the best option to choose for the ISP router/modem. There are newer models from AVM/Fritzbox that might also fit your needs.
Definitely have a look at the firmware tuning options for the Fritzbox like https://griggaudio.de/2022/08/30/fritzbox-audiophiles-setup/
Even though today's routers offer many functions for multimedia , they are not audiophile enough for higher demands. This is due, among other things, to the modest hardware quality , which is also due to the relatively low price.
Some functions can worsen the sound. This newsletter is about how you can improve the sound by making simple changes to the router's configuration. It costs nothing except a little effort
Hi Tom,Hello and good evening to you, Luca. If I may, please let me present you with what I have done. 2 moats and Wi-Fi. The reason I am offering this is just an FYI. IMO/IME, Wi-Fi is not as bad as folks make it out to be. It is an additional moat, and if done correctly? Will yield VERY similar results from that of an Esoteric transport, Mutec REF 10 SE 120, fine cabling in between with both that of my streaming rig and physical music.
Tom
I live about 2 miles away from a US Military “Space Force” facility. While there is very little to no actual people/car traffic to interrupt daily life, the interference from their satellite/tracking devices wreaks havoc on cellular and WiFi connectivity. Even my garage door opener can be shaky!
Thought about often…and I am as prepared as one can be.Just remember when the aliens attack that will be one of the first places they hit! Be prepared! LOL
Maybe helpful? Thread 'Which is the best SFP GPON module for Fritzbox 5590 fiber?'That's what I was referring to. Hardware wise the Fritzbox is most likely the best ISP router/modem option you can get. And in addition you can optimize it's audio quality by further tweaking the software settings for free.
Thanks Jason.FritzBox is the best option to choose for the ISP router/modem. There are newer models from AVM/Fritzbox that might also fit your needs.
I'm using the Aruba AP22 access point.Hello and good evening to you, Luca. If I may, please let me present you with what I have done. 2 moats and Wi-Fi. The reason I am offering this is just an FYI. IMO/IME, Wi-Fi is not as bad as folks make it out to be. It is an additional moat, and if done correctly? Will yield VERY similar results from that of an Esoteric transport, Mutec REF 10 SE 120, fine cabling in between with both that of my streaming rig and physical music.
Tom
Your comment provides a clear and detailed explanation of how Ethernet's asynchronous nature affects timing and jitter, and why clock accuracy might not be critical before the data reaches the streamer. Here are a few points of critique and areas for further exploration:No. Not in ethernet which is asynchronous by nature. If you can hear a difference by using a different/better clock in the ethernet domain, and it id evident that many do, it is not because of lower jitter = improved timing. It is most likely to do with the higher quality circuitry in the external clock being lower noise.
Jitter in ethernet refers to variability in the timing of the arrival of packets of data; it's a concern in overloaded corporate networks because at extremes it can lead to data transmission issues. It is not the same jitter we speak of once we unpack these data packets - after the 7-layer OSI ethernet model has done its job of ensuring the data arrives uncorrupted, with error correction and retransmission as necessary, At this point our streamer has unpacked the data packets/frames into a continuous bitstream for onward transmission to the DAC and clock accuracy is vitally important to sound quality in the (post-unpacking bit of a) streamer and in the DAC - but not before.
Extrapolation from the synchronous post-streamer world to the asynchronous pre-streamer world is inappropriate and unhelpful. Customers shouldn't need to understand this stuff but manufacturers operating in the pre-streamer domain have a duty to.
I'm with Hans's correction/retraction as referred to above. Isolation in the pre-streamer domain absolutely yes; noise reduction in the pre-streamer domain (including lower noise clocks) absolutely yes; clock accuracy in the pre-streamer domain absolutely no.
Wow!@Openklasse
Thanks for your well-considered post.
1. I absolutely agree. If one clock is lower noise than another clock, it absolutely can affect sound quality. I think we agree that this is nothing to do with clock accuracy. I have tried to be careful (but may have slipped up occasionally by using shorthand) to criticise claims that ethernet clock accuracy can impact sound quality rather than to criticise clock quietness.
2. Agreed. Noise causes no harm while it rattles around in the ethernet space. It doesn't even do any audible harm at the streamer itself, but the streamer's main job is of course to repackage the ethernet packets it receives into a bitstream which the DAC will recognise and in its turn convert to analog(ue). If we can stop noise reaching the streamer, we can make a major contribution to sound quality because it won't be forwadred to the DAC where RFI noise becomes audible through its impact on the analog(ue) componentry. Sure, we should also pay attention to how much noise gets from the streamer to the DAC and the right choice of cable here can also make a difference, but the focus of the thread is on the ethernet space.
3. Agreed (again!). I'd love to learn more about post-conversion-to-bitstream jitter for the benefit of my own audio systems if nothing else but I have much more to learn in this space before I can comment with any confidence. I enjoy living and learning...
4. On the manufacturer front, I guess my plea to fellow manufacturers in the ethernet space is that they take the time to really understand how asyncrhonous ethernet is completely different from synchronous post-streamer digital and not develop and market solutions to real problems in the ethernet space. As we know that the 7-layer OSI ethernet protocol will ensure the data (in our case representing music but the protocols really don't care) gets to its destination, the only variable influencing sound quality is RFI noise: it can be environmental, it can come down a wire, it can come across the ground plane... but in the network/ethernet space noise is all we can control.
5. I really do think that many manufacturers who promote the "issue" of clock accuracy in the pre-streamer domain are extrapolating inappropriately from the post-streamer domain, where we all know jitter is an audible thing and high accuracy clocks can have an audible impact. They need to be challenged to explain how ethernet clock accuracy can possibly affect sound quality when the data packets are transmitted asynchronously, subject to error-checking and if necessary retransmission, and ultimately converted to a completely different bitstream format by a device which has its own clock! I've seen some misleading "explanations" which talk about digital data not actually being 1s and 0s but being transmitted as an analogue waveform with curves and approximations and whatever: it's another completely erroneous extraploation from the post-streamer world to the pre-streamer world, and complete red herring in sound quality terms.
I'm not sure this counts as an expansion on all of your points but hope it helps and I'm happy to have another pop!
Huge thanks again for your excellent post.
Nigel
I have certainly observed, through listening, that an external clock for a switch, as well as an LPS for a switch, improve the sound but also contribute a sound (noise?) signature. That signature may or may not be what the consumer prefers in his setup and for his ears. How is the noise measured and the source(s) identified?Your comment provides a clear and detailed explanation of how Ethernet's asynchronous nature affects timing and jitter, and why clock accuracy might not be critical before the data reaches the streamer. Here are a few points of critique and areas for further exploration:
- Assumptions About Jitter Impact: While you correctly state that Ethernet jitter is more about packet arrival times and less about timing accuracy affecting audio quality, it's worth noting that the quality of Ethernet components (including clocks) might still influence the overall system. For instance, if an Ethernet switch or network card introduces excessive noise or interference, it could affect the signal quality even if the data is eventually error-corrected.
- Quality of Electronics: Your argument focuses on the idea that better clocks are likely to contribute to lower noise in the circuitry rather than improved timing accuracy per se. However, it might be helpful to elaborate on how this noise reduction translates into perceived audio quality. The relationship between electronic noise and audio fidelity is complex and not always straightforward.
