Thank you 'sig8'. Much appreciated.Ok. That is easy, but everyone (reviewers) claim it goes to another level with X1, but would certainly do in next couple of weeks. I will be installing units over the weekend.
The spikes will alter the sound. Whether it's better or not is subjective and you should experiment.Another question; is it necessary to install spikes for P1 and X1. Both units will sit on a shelf (not on top of each other). Do spikes improve sound (isolation)? Thanks.
Linking up all CH components into the home network and using a handheld device for remote is very convenient.I bought a Samsung Galaxy Tab A8 to use with my P1 last November. Still in it's sealed box as found I didn't need it as I could (and did) set up my P1 just with the from menu buttons.
Also have my P1 connected with an ethernet cable but haven't bothered using it i.e. with uploading updated software etc. as I am ok in how it currently sounds with my current UK based system.
p.s. I am also an avid Apple Macbook and iPhone user.
Mmmm interesting ! Thank you 'CKKeung' for the tip. Much appreciated.Linking up all CH components into the home network and using a handheld device for remote is very convenient.
However, after finishing all your setting up, please try unplugging all the ethernet cables from all your CH components and listen again.
You will find that the sound is much much improved.
Thank you for the interesting feedback 'mtemur' with the CH X1.IME sound improves slightly when CH X1 added to P1 but not too much. I heard X1 in a couple of setups. I heard two P1s and two L1s in mono together with two X1 feeding those 4 components. Every addition slightly improves the sound. If X1 is in the chain I recommend replacing stock umblical cables with better ones. The ones I heard were from Nordost if I’m not mistaken. That’s a big improvement IMHO.
I agree.Thank you for the interesting feedback 'mtemur' with the CH X1.
I am doubting I will hear any difference at all linking an X1 with my P1 when I am using the P1 connected to my Hifiman EF1000 headphone & speaker integrated (tube pre & ss power) amp with most of my listening with my Susvara Headphones.
At least not £14+k worth of sound difference !
I’ve just compared CH P1 + X1 vs Aesthetix Io Eclipse and I am very impressed. I am thinking of selling my Io to finance the purchase of P1. It’s not night and day difference, but it sounded just so much cleaner. Now , whenever I listen to Io, I feel it has slightly coloured presentation. But I still have my doubts. I am afraid of loosing a touch of tube magic that comes with Aesthetix, also, what if this ultra clean presentation of CH is not good for long term listening? Any thoughts? Has anyone moved from a tube phonostage to P1?
Hi 'abeidrov', Did you try the P1 vs the Io without the CH X1 as well ? If so, how what were the sonic differences you heard of the stand-alone P1 vs the P1 + X1 ?I’ve just compared CH P1 + X1 vs Aesthetix Io Eclipse and I am very impressed. I am thinking of selling my Io to finance the purchase of P1. It’s not night and day difference, but it sounded just so much cleaner. Now , whenever I listen to Io, I feel it has slightly coloured presentation. But I still have my doubts. I am afraid of loosing a touch of tube magic that comes with Aesthetix, also, what if this ultra clean presentation of CH is not good for long term listening? Any thoughts? Has anyone moved from a tube phonostage to P1?
Thank you 'abeidrov' for your reply and feedback. Much appreciated.Hi, I tried both P1 and L1 without X1 briefly, but I can’t say there was a significant difference. Maybe my ears are not good enough.
Have you tried a CH X1 'iaxel' with your L1, P1 and C1.2 ?I enjoy the best of both worlds.
I have an Allnic 7000 and a CH P1.
I only use the P1 with its current inputs as I find the “standard” MM/MC input under par at this level.
If you use cartridges with low impedance, the P1 is one of the best phonos out there.
I have not.Have you tried a CH X1 'iaxel' with your L1, P1 and C1.2 ?
In my system, I have yet to compare it to similar level electronics.How do you find the sound with your CH stack compared to other systems you have heard at this level ?
A+I have not.
I have the Aries Cerat Genus as well, and I find it at a very high level for an integrated amp.
As a follow-up, I plan to further explore Aries Cerat electronics.
The CH combo drives my speakers better. But the Genus has a magical tone to it that I could easily live with even if underpowered.How does your Genus sound compared to your CH L1 & A1.5 ?
