Hi!
Has Degritter done any research into the amount of heat to use for optimal cleaning of vinyl generally or the material composition of a vinyl record?
Optimal cleaning, if at all possible to define, will very much depend on the type of dirt we are trying to clean. Due to the undefined nature of "dirt" I argue there is no one optimal cleaning procedure (or temperature) for vinyl records.
You will find that ultrasonic cleaning studies will generally focus on "a very specific kind of dirt removed" vs some "very specific" adjustable external parameter, eg. temperature. There are many of these studies. Google Scholar will help with the searches. The first one I found:
"Cleaning of Conveyor Belt Materials Using Ultrasound in a Thin Layer of Water"
https://jfoodprotection.org/doi/abs/10.4315/0362-028X.JFP-12-563
There is a rule of thumb in chemistry: for every 10 C of temperature rise in a "common" reacting solution you achieve double the rate of the reaction. However when looking at US cleaning, there are caveats at play - the higher the temperature in water, the higher is the vapor pressure in the water and the more easily cavitation bubbles are formed and collapsed. This means less energy per collapse, less cleaning power.
The reason why commercial cleaners have heating elements and thermostats is that the chemical benefits start dominating over the cavitation intensity drop off at higher temperatures, achieving a better cleaning effect as a whole. But we cannot go into the typical 50-70 C ultrasonic cleaning temperature range with vinyl records.
As you see, there might be a balance (higher temperature = better solubility+faster rection rates - less cavitation intensity), but there are so many more variables that go into the mix. Following rules of thumb are pretty good for achieving 80% accurate enough results.
There is a famous example of the 80% rule from the Trinity atomic explosion - Enrico Fermi calculated on a napkin how much the blast yield will be, based on simple calculations and presumptions. His estimate was 10 kt TNT equivalent. The measured result was 20 kt TNT. Given how complicated this calculation would have been if one tried to consider all variables - well, you would probably had the same result as Fermi did due to the errors and whatnot involved. Not to mention the massive effort to compile the calculations. These kind of calculations are known as Fermi Problems.
What we know from experiment is that above 40 C records start warping - check. What we know is that room temperature (below which you need a refrigeration system), is around 21 C - check. This leaves us a range of about 15 C to play with. As you increase the temperature however, you lose some strength in cavitation. Based on this non-numeric herustic, I would estimate that the cleaning efficiency in terms of reaction rate and ultrasonic cavitation is pretty flat across the given temperature range.
I dare argue what makes a much bigger difference in cleaning than our given temperature range is the construction of the cleaning tank (directing the cleaning action), function of the ultrasonic amplifier (frequency and special functions, eg. sweep and pulse), cleaning medium and added cleaning fluids. General rules apply here too - you need something to transport the dirt away (water), you need something for polar dirt molecules (water dissolves sugars), you need something for nonpolar dirt molecules (surfactants/organic solvents eg IPA help dissolve fingerprints).
As for the question regarding shellacs - we have people using Degritter on shellac records with success. US record auction site Venerable Music has cleaned 10" pre-war era records with Degritter. There are pictures on our Facebook page of that.
Uku Püttsepp
co-counder at Degritter
