N
Reasons why Acourate is better:
1. Acourate can accommodate my setup. DIRAC cannot.
2. Acourate uses 64 bit floating FIR filters which include a great volume control all under a single dither stage. DIRAC does not.
If you want to use a digital volume control with DIRAC, you will be applying multiple layers of dither which is undesirable. Also, if one wants to use a digital crossover with DIRAC, it's best for technical reasons to use an an external unit like the DEQX. That's what I did. In this case, I was applying at least 3 levels of dither to the signal. DIRAC is really NOT designed for advanced DSP setups.
3. Acourate sounds much better in my setup.
I think DIRAC Unison may address some of these issues in the future. We will see. Since it took them at least 2 years to implement 192khz, I am not holding my breath for any big improvements in the near term.
I use a pair of mono subs integrated with a 3 way setup. The outcome is a stereo system with mono subs with 47hz, 12db per octave NT crossover and the same for RL speakers. Subs are on front and backwalls in a quasi-Geddes/Toole setup.I would love to hear why have you made the switch, would you share your considerations?
Thanks,
Ron
