Fair points...I think I like DSD128 best, so far. I can only play DSD256 and up on my iDSD, while I can play DXD and DSD128 on my Lampi.
Wisnon
It was the Sony CD/SACD player compared to a Theta Dac/Transport combo a long time ago.
I wish I spoke Japanese so I could download this DSD 11.2MHz Music for my Micro iDSD...I am afraid I will, even with Google Translation, make a horible mistake and not get my music...
http://ototoy.jp/feature/20141001/DSD+11.2MHz解禁!!+SOILのピアニスト丈青のソロ作を“最高音質”で
Hi
I am open to change my mind and/or stance on certain things. Many here claim that DSD is superior to PCM. Several DACs actually perform internal PCM to DSD conversion and the results are much loved by some audiophiles. I have heard some DSD that sounded great and some not so much as in any format BTW.
What titles/Discs/Pieces do you know that would allow a fair comparison? Same mastering different coding. That would show off the aleged superiority of DSD?
You can easily compare yourself, if you play FLAC and DSD on your DAC from the files in the link below and can't hear a difference you can assume your DAC is converting DSD to PCM, i can clearly hear the difference and I love DSD, DXD also sounds amazing in my DAC i wish we can get more of it and soon.
http://www.2l.no/hires/
For a fair assessment of DSD vs. PCM, you need native files in both formats, instead of some up/down sampled file!
If one thinks FLAC is better than DSD or they sound the same, then converting DSD to FLAC should sound the same, all the time.
ANY digital conversion from DSD -> PCM or the other way will degrade the signal.
You do realize that DXD is PCM?
Agreed. I was supporting your position and directing the poster to 2 examples or native format recordings from the same session.It is my understanding that 2L records exclusively in DXD.
I have one album that is available from Sound Liaison, "Impromptu", which was directly mastered in 24/96 PCM and DSD64 in parallel which could be used for such a format comparison.
