Thats pedantry in the extreme. You know precisely what I was referring to. So "dealing" is the new term for "joining"?
Let's be pedantic like scientists would be and have you explain to us precisely how the Entreq 'joins equipment grounds together'.
Actually if you have paid attention to my posting you will find what I have said is that it doesnt do anything over what can be achieved with cheap ordinary cable and a connector block. Also that if it is necessary you need to be looking at a more fundamental level at the (signal) grounding regime in your system as it is obviously deficient.
You are aware that people who have balanced/clean power or balanced ICs, or great chassis-grounding solutions (Tripoint Troy) have still reported additional better SQ with the Entreq?
You should be asking "why do I need this"? Your equipment clearly isnt effectively performing a pretty fundamental function.
No, the more interesting question is why people who already have good grounding still find additional benefits and how does it work and whether that fits an existing Engineering and Scientific corpus of knowledge.
As an aside, most wont know if they have a noise issue anyway. Without measurement most wont know if the Entrail has made this better or worse or no different. Yet Im sure they will convince themselves its a massive improvement, especially after spending thousand of $ on it....![]()
The name of the Brand is Entreq not Entrail.
It would be interesting to know why if your system is supposedly very good at grounding, you couldn't hear any difference in the initial set of files provided by Fiddle Faddle in your system. It's obvious this is a far bigger issue for you here.
