Ever read the story of Galileo and the flat earthers?
Ever read Ohm's law?
Some early impressions from my trial.
I have so far only heard the Entreq with Apollo RCA ground cables to the line stage and a few hours to settle in. As others have mentioned, the effect does build up gradually and I did not fully realize the extent of it until I disconnected the ground cables toward the end of the listening session.
Interestingly, with my line stage, which is dual mono, grounding separately the left and right channels was key to appreciating the effect of the Entreq, to the point that I might have passed on it if I had only heard it with one channel grounded. In other words, when I started disconnecting the ground cables one at a time, most of the drop in sound quality occurred upon removal of the first cable. Removing the second cable had a marginal additional impact. I am glad that rockitman and allvinyl mentioned this earlier in the thread, as I might not have thought about it otherwise.
The general impression is that of increased energy and dynamic contrast, perhaps due to quieter background. Everything is more vivid and tonally saturated. Instruments and voices have better and more focused projection in the room, increasing the perceived realism and soundstage depth. I can also listen at a bit lower volume before the music acquires enough impact.
I am looking forward to finding out how much more can be obtained with additional settling in, optimization of the ground cables and the grounding of additional components.
Have you tried asking a friend to remove/connect the grounding boxes whilst you are unsighted?
Keith.
I have pulled cables and added them back in unsighted (during my 4 hour demo) and not even in the sound field (off to the side) and I can still hear the difference. Rather than speculate as it may be difficult for you to wrap your brain around the concept (like it is for many)...try them out yourself with a demo.
great comments/insights....nice system by the way. Yes, in my experience it is:
20 minutes
3 hours
48 hours
2 weeks
then stable. i'd say you should have a nice improvement by around 3 hours...and then it steadily advances all the way thru 48 hours (not of playtime...just from when you've hooked them all up). And though no doubt you might have acclimated to the sound at that point...taking them out is generally quite a surprise (in terms of grain that appears which at least for me, i did not realized was there). And then you have to start all over again and wait the 48 hours.
Good luck and look forward to ongoing comments as to how it works out for you.
dmnc02,
How do the improvements from the Entreq(Tellus?)with Apollo RCA ground cables compare to your other tweeks?
Do you have access to a multimeter?
If so, are the RCA grounds in your preamp's left and right channels connected to one another?
Are they connected to the ground pin of the IEC input?
A box placed on the floor , ( filled with what exactly ) plugged into a spare preamp input cannot make the slightest difference to sound quality.
There is nothing to wrap my brain around ,your equipment should be earthed through the mains, unless you have been foolish enough to disconnect the earth.
Keith.
Keith.
Mark Hi, can you open the Entreq box I would love to se what is inside , and how can power leads possibly make a difference!
KR Keith
Expectation Bias is your friend.
Keith.
Purite and Deverts contributions take me back to my childhood and a saying(in standard English as opposed to the colloquial original) that "There are non so deaf as those who do not want to hear."
How little has changed in more than 50 years!
