Well, I'm putting myself under the objective/subjective spotlight. For the first time in a while, I've deliberately disconnected Entreq from the whole system, and then reconnected, and noted the differences.
The reasons? Well, w/the objectivist drive to scorn all things not easily measured/explained, and Entreq can fit into this, I need to challenge my experiences and possible preconceptions.
I would like to know if placebo/expectation bias really is the issue here re impvts I report I've heard, or if they are genuine/tangible.
I can tell you I was pretty anxious, maybe £4500 worth of egg was about to land on my face!
Well, it's not definitive for the scientific crowd, but changes were immediately noticeable - on disconnecting the lot, a shrinking of the soundstage to btwn the spkrs, less solidity, and a sort of "grey" quality, all resulted, the music lacking colour and drama.
Reinstalling, and just 30s later, things are perking up - not radical, but the promise of things to come. Confident 24hrs will do it.
Boys, I am MIGHTY relieved.
So confident am I that I'm not deluding myself, I've made an offer for arch objectivist Keith (he lives not far from me) to come over and do a tentative blind trial. Over to you Keith.
Spirit, that is a nice offer, but I am really curious as to how you can possibly do a meaningful blind test.
Keith has clearly stated his prior that grounding to the Entreq cannot possibly make a difference. Thus, in an A/B test he is going to be inclined to hear no difference, whether he is blindfolded or not. In other words, blindfolding him is not going to help to overcome his expectation bias.
Alternatively, since you have stated your preference for having the Entreq in the system, you could be the one to be blindfolded in order to test if you can correctly identify when the Entreq is in the system. But the problem with that is that the full effect of the Entreq takes days to build up and so the logical sequence is to listen with the Entreq first and then without, in which case once again blindfolding you does nothing to overcome any expectation bias.
If Keith does accept your invitation, it would seem to make much more sense to just enjoy the system with the Entreq, then remove it, and let the magnitude of the difference be the only factor at play to induce him to revise his prior. Forget about blind tests
