I think it is obvious that I was talking about polishing the outer part of the Ultra 5s.
which makes the notion even more unbelievable. Glad it works for you.
I'm hardly skeptical about Ultra 5s having put my whole system up on 30 of them but I have to admit I seriously doubt the notion of polishing them for improved clarity. Not saying that its not possible but rather it's just not a fit with their design approach but look forward to any comment from Stillpoints USA - but I fear with these kind of claims that the flat earthers may well eat us alive!
On the Entreq Silver Tellus I found similarly variable results from component to component with some outcomes as John from Stillpoints found with his Berning pre. In context of my system I found great results with that wonderfully fluid signature Entreq musicality when applied to my Shindo pre but then not so beneficially for my amp gaining additional fluidity but also losing some structure and sense of attack. Another example how variable these kinds of things can be and the importance of a home trial.
I have implemented both Shunyata and Stillpoints products comprehensively throughout so also going into Entreq for a grounding approach could be just over cooking the duck a bit (to lovingly quote my grandmother). I loved Entreqs effect on the preamp but everyone's mileage is gonna vary given how powerfully yin it is in nature and also how a mix of Shunyata and Stillpoints might be sufficient to the task of mechanical and electrical isolation without Entreq. I could well imagine had I not used Shunyata and Stillpoints quite so intensively then clearly a different but cost effective noise minimization approach could have been just using Entreq alone. A mate with the amazing Tune Audio Anima horns with SET amps runs a Typhon with Shunyata Anaconda cables and also the Silver Tellus and this sounds brilliant with the Entreq in the mix. Clearly Shunyata, Stillpoints and Entreq do similar things in terms of lowering the noise floor but they still manage to sound quite different to each other so the mileage with each mix is as usual going to vary.
Has anyone removed the stock wooden feet from their Tellus and used Stillpoints adaptors to attach Ultras?
The UK Entreq distributor has never suggested that to me but certainly recommends using Stillpoints with them so no never tried it.
Yes that Stephen R. Macatee of Rane Corp. paper was published in the same ASE Journal as the Neil A. Muncy Pin 1 problem paper.http://www.rane.com/note151.html
Here is an interesting 'technical article' (at for a non-techie like me) that i have only just begun to read...but it specifically goes through chassis ground vs signal ground...
I've just received 2 Atlantis eartha cables to test with Olympus and Silver Tellus.
but look at here this is very interesting:
https://www.youtube.com/watch?v=cDbhilaTgDY
Thanks for that.
Just watched the interview.
Look forward to reading how the new cables and box work in your system,
