Bigpond from Australia is using audio Research 40th anniversary preamp with his mephisto solo driving his Alexandria
I have. My friend Danon was the first person to purchase the mephisto stereo in Malaysia. Within a few months after the purchased he demoed the Solo & it's a done deal. My CJ Act 2.2 has a gain of 20.5 , pretty high & I don't have noise issue with CJ 350. The hummed you have experienced is due to the amp grounding issue . All I did thru my dealer is to add a 47ohm resistor to the safety ground terminal at the back of the chassis & the hum was cured !
Loyd,
What preamplifier is he using? The only drawback I see in using the Mephisto with Alexandria's is the high gain (31 dB) coupled with 94.5 dB/W. When used with some tube preamplfiers we risk to have some residual noise. I did have this problem with the cj 350 (32 dB gain).
Do you know of anyone having compared the Mephisto Stereo with the Solo's?
Loyd,
Lloyd,
The Antileon you had was the regular one, or Signature ?
regular...i decided to skip over the SE edition and go straight to Colosseum. That said, i did love my Antileon and i know a distributor who still talks about his old DM100 from many years ago...
Lloyd,
You must really grab the opportunity to listen to the Mephisto. Its performance is so superb that I'm at a loss for words to describe it. Top to bottom, it is so perfect that it's mind boggling. I didn't know what the Extremas are capable of until I drove them with this Gryphon unit.
Lloyd,
What's mind boggling is the price you pay for 175 watts. I would hope that if you shelled out anywhere close to $100K for this amp you do find it mind boggling. The Mephisto (why does that name sound like someone who speaks Spanish trying to describe to someone who speaks English about the big meal he just ate?) is stated to be a Class A amplifier. Has anyone determined how many of the 175 watts are actually Class A watts? I read one Australian review and the reviewer said that the Mephisto doesn't run that hot which is surprising if it operates in Class A at any significant power levels. I do think this amp looks pretty cool and I would love to hear it, but not carry it.
I thought the review I read was for the stereo version and it was $100K. I was surprised they said it didn't run that hot given that it's supposed to be a Class A amp. I assumed the reviewer would have run the amp on the highest bias setting-what would be the point otherwise? Pure Class A amps should run very hot as it's the nature of the beast. My Krell KSA-250 runs damn hot and JA said it was only around 35 pure watts of Class A power. When you walk near my amp, you can feel the chimney effect from the heat.
And Lloyd, I read the specs on their site and they didn't publish any figures for the power continuing to double down to .5 ohm. If they did, I missed that. The KSA 250 actually does that trick-4000 watts at .5 ohms.
Although these specifications are important only when you are using your amplifier to power your welding station the Mephisto is rated at 9000W peak at 1/4 ohm load. The class A power must be given for a defined impedance - Gryphon specifies it at 8 ohm. A figure for class A power without impedance specification has no meaning at all. And just to finish, heat and temperature are different things. The Mephisto has better designed heatsinks than the KSA250, it will have a lower temperature for a similar idle power.
Did I win a Gryphon Mephisto?![]()
