Same speakers, different century !That is a beautiful sight.
Almost as good as the one where- I think it was your place - in what looked like a high rise bright condo with another beautiful system.
May I ask what is the slope used in there cross overs 6 or 12 ??
So to make myself under stand this a typical cross is 6db and 12 dbWilson never mentioned the crossover specs so I do not know but I guess Alexandria use 4th order crossover
A forth order uses 4 elements and is 24 db is this correct ?
See you know lol. there is so much in a simple speaker and to make one on the scale of large Wilson’s is a lifetime commitment always improving until you stopYes 6db for each pole. L/R 24db 4 poles 4th order. 1st order 1 pole and so on 3rd 3 poles. Remember that is electrical only. Speakers also roll off and horns roll off so the actual acoustic crossover slope doesn't always match the electrical. Depends on the driver types and crossover points.
Rob![]()
Imagine asking your date "Do you want to see my Naked speakers"?I can't wait until they start showing the all new IO Design Naked RS Loudspeakers at the Shows here in the USA soon !
www.iosoundesign.com
is that the same speaker that was called YAR?I can't wait until they start showing the all new IO Design Naked RS Loudspeakers at the Shows here in the USA soon !
That’s quality service!When i bought my first set of Martin Logan Statement E2's a team flew into Miami to assemble and set them up. Someone from ML came back on 2 occasions after burn in to take measurements and make subsequent adjustments, they also supplied me with a full set of extra spikes, because i liked the design of the ones used in their original advertising, later production models had changed. And when i had a balance discrepancy they sent me a full set of crossover electronic and extra set of electrostatic panels, for free ! Gayle Sanders was still running the company back then, that was fantastic service !![]()
(...) If there are technical explanations for many his observations, I'd love to learn what they are from Wilson. One can guess that that manufacturer's reply will be likely based on the adage that the "proof is in the pudding" which is namely, how they sound. While it would be easy for Wilson to dodge the answers as any good politician would do by saying they make them the way they do because that's how they get them to sound the way they do, I would find such an answer somewhat of a disappointment and unsatisfying. I'd like to understand the physics that underlie the design a bit better, but I doubt we'll see that here. I suspect that lobing patterns as Amir points out in post #449 are an important consideration (as they usually are with 2nd order crossovers) and this probably enters the realm of proprietary work that Wilson would be reluctant to share. In the end, despite some great posts, we're probably at a point of "go home folks, nothing to see here" as much as we'd like to be able to see and learn more about the rationale for the design of the Wilson speakers.(...)
Have always loved the stories of your earlier and wilder days Milan.When i bought my first set of Martin Logan Statement E2's a team flew into Miami to assemble and set them up. Someone from ML came back on 2 occasions after burn in to take measurements and make subsequent adjustments, they also supplied me with a full set of extra spikes, because i liked the design of the ones used in their original advertising, later production models had changed. And when i had a balance discrepancy they sent me a full set of crossover electronic and extra set of electrostatic panels, for free ! Gayle Sanders was still running the company back then, that was fantastic service !![]()
MartyI just spent an hour catching up on this wonderful thread. I thought Brad's post #328 was the finest post I've read on the WBF in quite some time. I must admit I never understood the merits that "the decay of the tweeter output should blend with the rise of the midrange output, etc.". I agree with Brad and others who cited John Dunlavy and other (i.e. Vandersteen) when he described what he considered proper driver time alignment.
But here's the rub. Despite the comments by many about the strengths and liabilities of the driver and crossover design of the larger Wilsons one can only cite the obvious which is namely, that this was done for a reason. It would of course love it if someone from Wilson would indeed chime in as many of the questions Brad raised are serious and thoughtful. If there are technical explanations for many his observations, I'd love to learn what they are from Wilson. One can guess that that manufacturer's reply will be likely based on the adage that the "proof is in the pudding" which is namely, how they sound. While it would be easy for Wilson to dodge the answers as any good politician would do by saying they make them the way they do because that's how they get them to sound the way they do, I would find such an answer somewhat of a disappointment and unsatisfying. I'd like to understand the physics that underlie the design a bit better, but I doubt we'll see that here. I suspect that lobing patterns as Amir points out in post #449 are an important consideration (as they usually are with 2nd order crossovers) and this probably enters the realm of proprietary work that Wilson would be reluctant to share. In the end, despite some great posts, we're probably at a point of "go home folks, nothing to see here" as much as we'd like to be able to see and learn more about the rationale for the design of the Wilson speakers. Then again, Alon Wolf and other designers aren't sharing their design secrets publicly either yet nobody seems to be frothing at the mouth because of that!
But this thread has been so good, I am considering a Go Fund Me campaign to support an all-expanse paid trip to send Brad to the Wilson factory so he can drive them all nuts for a few days.
i would love to hear the statements. The hybrids are still a fantastic value speakers, one of the few current companies that makes speakers that reproduce music. Maybe older models from Sanders’ time were better like some say, I do not know.
What's a better system ?
$200K speakers + $50K electronics/cables
or $100K speakers +$150K electronics /cables
I actually don't care how Wilson designs their speakers...they have chosen their tradeoffs. I have a problem with claims that aren't really true.I just spent an hour catching up on this wonderful thread. I thought Brad's post #328 was the finest post I've read on the WBF in quite some time. I must admit I never understood the merits that "the decay of the tweeter output should blend with the rise of the midrange output, etc.". I agree with Brad and others who cited John Dunlavy when he described what he considered proper driver time alignment.
But here's the rub. Despite the comments by many about the strengths and liabilities of the driver and crossover design of the larger Wilsons one can only cite the obvious which is namely, that this was done for a reason. I would of course love it if someone from Wilson would indeed chime in as many of the questions Brad raised are serious and thoughtful. If there are technical explanations for many his observations, I'd love to learn what they are from Wilson. One can guess that that manufacturer's reply will be likely based on the adage that the "proof is in the pudding" which is namely, how they sound. While it would be easy for Wilson to dodge the answers as any good politician would do by saying they make them the way they do because that's how they get them to sound the way they do, I would find such an answer somewhat of a disappointment and unsatisfying. I'd like to understand the physics that underlie the design a bit better, but I doubt we'll see that here. I suspect that lobing patterns as Amir points out in post #449 are an important consideration (as they usually are with 2nd order crossovers) and this probably enters the realm of proprietary work that Wilson would be reluctant to share. In the end, despite some great posts, we're probably at a point of "go home folks, nothing to see here" as much as we'd like to be able to see and learn more about the rationale for the design of the Wilson speakers. Then again, Alon Wolf and other designers aren't sharing their design secrets publicly either yet nobody seems to be frothing at the mouth because of that!
I am only focusing on the claims...I don't actually care how they design their speakers.Marty
A friend has a nakamichi self centering TT .. the before and after demo makes you believe self centering is the be all and end all.. then he gets an airforce 2 and you completely forget about self centering. Speaker design has vastly more tradeoffs than TT and Brad is focussing on one aspect, both as a false claim and a design issue and I think the 2 have got a bit mixed up ( not by Brad). Marketing spin aside the wilson step response is quite good in terms of overall time (as Brad notes) and I suspect the second order is chosen for that reason ... to allow the smooth transition in the shortest possible time ( in combination with physical alignment)...and have a decent slope on filters. I wonder what the step response of non dialed in wilsons looks like ?
You certainly can hear the effect of true time correction as Brad notes but its first order or digital that gets you there .. first order has its cross contamination problems and digital is the answer that is yet to be fully embraced.
It would be interesting to hear digitally corrected wilsons !
Wlison et all have all picked their path of tradeoffs and resolutely plough on. I wonder if it is partly to maintain value of previous models. It seems rare for major brands to change tack .. atmasphere from tubes to class D is one dramatic swerve I can think of
It is an interesting thread indeed .. if only there was a pointless bickering filter...
Cheers
Phil
