Has anyone on here heard the idler drive TT SMD Acoustics based in the UK?
https://www.peakhifi.co.uk/cgi-bin/ecom.cgi?Command=ShowProduct&db_pid=709
Ddon't forget that all of these old idler have been built when the main in Europ was 220 volts maximum. So powering them at 210 220 volts give a better result, cleaner treble...
https://positive-feedback.com/reviews/hardware-reviews/the-hanze-hifi-hat-turntable-power-supply/
Looks interesting, but an idler without a massive plinth is something of a concern.
I very nearly went down the low torque route again in 2011 w the (now sadly discontinued) Palmer 2.5 (I believe descended from the NA). It sounded v special thru Harbeths.
But high torque speaks more to me, and hearing the Salvation the same day as the Palmer was instructive.
Good idea, let's do some calculations. Im considering a turntable where a motor drives a platter through a belt.
I've used parameters which are sort-of garrard'ish -- but belt driven.
I did a spreadsheet to compute 4 different things:
1. The resonance frequency of the belt-platter system. Thick rubber band => 3Hz, Guitar string => 13 Hz.
2. The platter rotational energy. = 0.41 J [Nm]
3. The torque of the motor. = 27 Nm
4. The rotational energy of the motor. = 0.5 J [Nm]
Unfortunately I cant upload the spreadsheet but I'd be happy to mail it to anyone interested.
Im unsure about the parameters used to compute 4 but it cant be magnitudes off.
What is clear is that the (electric) torque of the motor is a way bigger reservoir of resistance to speed change
and stylus drag than the platter or the moving inner bits of the motor. In fact, to match numbers the platter would
need to be approximately 200 kg placed in a 15 cm radius.
Hence, the drive system (the belt) matters. The point here is that any non-constant stylus drag will trigger a cyclic movement
in the platter relative to the motor (wow) at a resonance frequency that is determined by the mass of the platter and the
spring constant of the belt. If the belt is a thick rubber band you get a resonance frequency of 3 Hz and if its a guitar string
you get 13 Hz resonance frequency. Take your pick. This resonance will be dampened by the damping of the band only.
Crucially, this resonance is correlated to the music.
BTW2: The LP12 wobbles in all dimension, including spring suspension between motor and platter. The only clear beat
Ive heard with the Sondek was the sales guy stamping his foot behind me
Jesper
Ps! I would like to see the paper if you have it.
I'm not sure what the risk with a periphery is.
Unfortunately I do not have access to the paper anymore - it is an AES copyright, reserved to paid subscribers.
Thanks for your interest, but I am sorry I can't keep up with your study, in order to go on the subject properly I would need some extra free time. But it seems to me there is some mistake in your spreadsheet or in my understanding of it - the energy of the rotating turntable platter is usually quoted to be between several hundred and a few thousands joule and you report less than half of a joule (.41041 J) .
Anyway it seems to me such idealistic simple approach would be chaotic - small variations in the poorly known values would lead to enormous differences in the conclusions. But it is just a feeling ...
It seems we disagree on the Sondek. I was a lot younger at that time, but the damn thing had a lot of rhythm and beat for rock. And I can't believe that the tens of thousands of owners who found so were all wrong!
In my mind (since I have not used a ring) the risk is simply handling a large metal ring around a record and cartridge. The amount of space between headshell and platter, getting it centered on the record, the reduced amount of lead-in groove available for the cantilever/stylus, removing it from a record, sitting it somewhere to change the record, etc. This is not criticism of what you're doing - just thinking about what is involved in using one. No doubt you are adept with it.
I'm guessing your's is the larger Kuzma bronze ring, circa 4½ lbs. I believe Kodomo is also using the ring.
Using a ring is not challenging. It's an extra step, yes. But analog is itself a time investment, and periphery rings are really nothing in the grand scheme. Top Wing are the first carts I've encountered that ride low enough so as to make contact with my periphery ring. And there is but one Kuzma periphery ring option that I'm aware of when you buy a Stabi M. To my knowledge, it's the same ring used on the XL DC as well. I don't know if it's brass, but it has decent mass. 4-5 pounds sounds about right.
Dave, my rim drive is an evolution/mutation of the L75. Vic the designer has taken the basic concept, and managed to crack some of the technical challenges, esp re minimising rumble, and it's transmission to the stylus. If you Google "From Lenco To Salvation" on Lencoheaven forum, you'll see a heroic effort to preserve the inherent vitality of idlers, and addressing those weaknesses that can limit the highest performance.
