As usual you miss the pointThat says it all. Your opinion is irrelevant to this thread incidentally named.."Incredible Stillpoints".![]()
As usual you miss the point. The fact that there are people on this forum who are NOT Stillpoints fanboys ( like you) in your opinion disqualifies their opinion ( even IF they happen to have tried the Stillpoints and discounted them). I don't have a horse in this race...BUT you sure do..a "blinker'd" one, LOL.
Vice grips
Great idea.
Chew up the threads and make them worthless.
Madfloyd, get some lock nuts the same size as the adaptors and you'll be able to back them out with a wrench.
Makes you appreciate that WA has an allen head insert on one end of their threaded inserts to assist with removal.
Christian,IF ( BIG IF ) you were to read my posts, you would see that not once have I ever said that Stillpoints do NOT work. Instead, I have commented on the fact that they did NOT work for a friend and also apparently for Peter A. That is VERY different statement. However, you go on to state that :" But if your system is up to the task, still points can allow you to maximize the best sound from your system componentry". That statement is at the VERY least highly encompassing --or some might say conceited...Nah
I'm done discussing this with you.
Still bashful to share your system tough guy ? LOL Jap. It's past your bedtime.Yes, just like your genius of telling Peter to use double sided tape to make the Ultra 5s work with his Mini IIs.
What does that have to do with your genius double sided tape recommendation?Still bashful to share your system tough guy ? LOL Jap. It's past your bedtime.
Yes, just like your genius of telling Peter to use double sided tape to make the Ultra 5s work with his Mini IIs.View attachment 14294
The Stillpoints threaded inserts have an Allen head insert on one end......Makes you appreciate that WA has an allen head insert on one end of their threaded inserts to assist with removal.
A self-contradicting statement....I am not saying they work for everyone for every component, but if your system is up to the task, stillpoints can allow you to maximize the best sound from your system componentry.
This may come as a surprise, but the highly popular captive ball in two cups device is actually viscoelastic.
In the vertical plane, the ball and cup is a very effective coupler. The small contact patches providing an almost spike-like contact area.
Considering the forces in the horizontal plane, as the ball rolls, there is friction between the ball and the cup. This results in a loss of energy, a generation of heat, and a viscous property. Depending on the material of the ball, and the material of the cup, you will have different coefficients of friction.
Hence, the ball and cup and related ball and race devices are a special class of viscoelastic coupler/decoupler, with almost perfect coupling in the vertical plane, and viscoelastic properties in the horizontal plane.
2) When there is viscoelastic behavior horizontally, the reaction of the suspension lags the strain by up to 90 deg. Hence, the reaction is no longer clean. An impulse from the woofer may be returned by the loudspeaker cabinet suspended on the viscoelastic pucks out of absolute phase with the impulse, resulting in the impulse being smeared in time.
The effect combines the impulse signal (cone going forwards) with an attenuated, inverted signal (speaker cabinet going backwards) chaotically resulting in a muddy sound.
I am not a fan of viscoelastic pucks because of the out-of-phase response. Elastic pucks (on the other hand), carefully applied can be extremely effective.
1) When the pucks behave elastically both vertically and horizontally, it is likely that they are squished so hard that they become a solid vertically – and hence become an excellent coupler. An example is a small blob of blu-tac used to secure a loudspeaker to its stand. If there is elasticity in the horizontal direction, the strain is in phase with the stress, and thus reduces cleanly nett horizontal forces. An impulse at the loudspeaker causes the loudspeaker to bounce backwards (you have to remember that the loudspeaker is many times the mass of the driver cone) but when it is elastic, the bounce is clean and you get undistorted but reduced impact.
rockitman, you should allow for the possibility that some (maybe even many) systems won't benefit from Stillpoints, or may benefit in only small ways or very specific implementations as with almost any tweak.
Great idea.
They need them on the other end as well.
