WOuld like to add my 0.02 Euro to this. I understand your insistence on the system approach but I would say that it begins with the speakers. Some large speakers, the old Magnepan for example would never entirely disappear it was in their DNA, I would venture to say the design had some flaws which would never help them project a small image, regardless of the electronics used and believe me I have heard them with anything from Monster Amp to OTL Tubes passing through SET. They have progressed to a point where the new Maggies, the .7 series can and will disappear with proper set-up. I do not share your point about electronics and the "disappearing" act , I know of some speakers that simply disappear inmost roonm with almost any electronics, the old Spica TC-50 were master of this disappearing act, regardless of electronics or front end.
As for Sonus Faber I have experienced the Electa Amator doing a strange "I-am-not-even-there-so-where-is-the-sound-coming-from?"but the sound was as big as any speakers had any right to be... To me one of the best Sonus Faber ever...
As for Wilson the X-2 works on small scale as well as any speaker large or small... heard it doing so with various electronics...
Housings such as kharma builds will surely help with the disappearing act , there are certain levels of disappearing, with very good speakers you only hear music
IMO very good loudspeakers with relatively cheap amps , will still disappear in room , dont skip on speakers.
Only negative thing i found on this thread is that that building in china definetively needs an elevator![]()
funny thing is that the last time i was in breda ( quite a few years ago ) , the best amps i heard the kharma classics on (with ceramic mid ) was on their Kharma P -150 pre amp and exquisite poweramp (digital iirc ) , ive heard kharmas on lamm , boulder and their 1000 series own designs .
That P-150 pre is definetively one i want to try out some day
One thing they excell at is ease of presentation while staying very detailed , kharma has gone through extreme efforts to make a non resonant housing , its all made of sections of material put together (this means a lot off waist material ) .
I havent heard all of the big speakers , as they are not all represented overhere.
May be you should also have a listen to my latest design one day , they are probably a mix between the 2 wilson and kharma and easy to drive , resonance is merely a thing from the past
Well ,magico has braced alu alloy extensively with stainless steel , probably one of the reasons the Q 7 is so heavy .
IMO phenolic resin based cabinets which " probably " include wilson audio X material ? and kharma ( HPL ) my design is also HPL based , are just a little more non resonant then alu alloy based ones.
I never heard the Arrakis unfortunately or any rockport speaker for that matter
Maybe Loudspeakers should be selected according to weight
The carbon fiber which is used in the Rockport as well as the M project is merely to make it all look sharp i think , which is also important to sell a product
Maybe Loudspeakers should be pre - selected according to weight
The carbon fiber which is used in the Rockport as well as the M project is merely there to make it all look sharp i think , which is also important to sell a product
If so please enlighten me whatfore or is it a secret ??
For speakers you generally need non resonating weighty materials
