I use Jcat reference cable custom version with only one strand- no power , you may order such a version with Marcin Ostapowicz from Jplay/Jcat.
So what is difference between this and any other good USB cable, since you are not using the power?
Hi Marslo
Would it have the same effect if I only connect the data strand and just don't connect the power strand of my dual strand-dual connector Lightspeed usb cable?
That should work, Christoph.
In fact funnily enough I suggested to Mark @ Sablon that he could design a prototype of this configuration about 6 weeks ago for the same reason.
All - does Lampi need a "handshake" of power? The dual headed cables were designed to allow the handshake and then you pull the power out as I understand.
Audiophile Bill,
Will be very keen to give it a listen if Mark decides to follow your suggestion.
The power conductor carries any high frequency noise from the source. Separating the power lead either physically or electrically by shielding does help mitigate the impact upon the data wires, however dropping the power will get rid of it completely
Thank you Mark, look forward to it.Thanks Marslo, will put you down for an audition!
Is this not a concept that some manufacturors have already implemented, such as eg the Curious usb cable?
It is a reasonably well known concept, having come to attention with the dual headed Acoustic Revive USB cable several years ago.
I played the Kron px4 tonight not long just wanted to hear them
I burned them in for two hours first before a listen.
The tubes are nice they seem to be a 45 sound
Who said they sound like the px25 ?
They are along the lines of the anniversary eml lampi mesh 45
I did not do a direct A/B yet.
For me on my setup playing hi Rez dsd they lack the weight for good piano and vocals are light for men and woman
They are clean well detailed no vailing
They seem well
Proportioned in sound all around
If I add more bass to my towers they are very nice
Has anyone done a direct with the 45 mesh globes
They are close I think and I wonder if it adds in some ways
The tubes are very microohnic for me but as I use a preamp it's not an issue
More tomorrrow I also used the Kron 5u4b and tak recti
They seem well
Good morning.
The tak or we 274b are worth while improvements
The Kron 5u4g is a very recti perhaps in some ways better than the rest of the group in noise level
Less grain , more musical
Now when you install one of the other two is a big jump
First is staging they both increase this in all dimensions pretty amazing
Now we must consider this is all an illusion no one knows what is really on there
While it achieves this it also makes the music much more natural sounding
I think this happens and is part of the staging increase
My main rig is the IRS v setup Ina large room made for them
All recti gives me staging even the solid state recti do and do this well
But no other recti does this in front to back and top to bottom.
Depth is the real staging that makes me feel it's real.
We all have recordings that have better or worse staging
The better recti shows better or worse but also improves the sound weather it's staging better or not
The difference between he tak and we274b is minimal
But it's there one add is the tak is a bit bass heavier so if ones systems needs this it's the better choice
As I say it's better please consider its me and we each have what we deem better
But consider this of the many posts I read and others I know who have them in other than dac setups as well the two above are a tube they prefer.
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
