Lampi GG 512dsd + 44k + 48k superclocks + RTR PCM + KR242 + grounding post + SGM server----
Wow, that implies that the DXD tracks are beating the stellar DSD128 tracks that I know you have. Hard to fathom that the R2R engine can beat the chipless dsd512 engine!
Hi Norman, the 512 engine is actually chip based. I spoke with Lukasz earlier to clarify since a couple of people had been asking me about this.
my first non-reflective reaction would be no. then, after considering the very best of what I've heard I would say 'a little'. some of the native dxd particularly gets closer. all the graphs need to line up. makes me want more dxd files. I think the SGM server does make a significant difference.
but; the needle drops and we are not in Kansas anymore. the Goldfinger Statement is improving too.
I will refrain from saying that "native DXD" is a non native format ;), but can I ask you where do you source DXD files? The few ones I own sound really great on the Vivaldi, but are not in quantity enough to get an overall view of the format!
i know Mark...its just a shorthand for DAC-chipless DSD. But Dac-Chipless is too unweildy a term to use. LoL
The idea is to distinguish this from the generic DAC chip approach most manufactures use for DSD, as opposed to the discrete layout of the chinless approach which is essentially an elaborate filter box.
too soon for any absolutes. just commenting on what has grabbed my attention so far. but dxd on the right PCM dac is compelling. I always wondered what dxd might sound like if the Trinity dac could handle it.
Understood, but I would not have expected it to even be close!
Do me a favor...play back St James Inf by Satchmo native rate DSD128 and let me know what you think.
For the technically challenged like me, can someone explain a bit what is the difference between DAC-chipless vs. the "regular" DSD256 engine in the Atlantic/GG?
i know Mark...its just a shorthand for DAC-chipless DSD. But Dac-Chipless is too unweildy. LoL
Go to the 2l and spirit of turtle websites, Micro: quite a lot of marvelous sounding dxd files can be downloaded from these sites.
The DSD256 module in the R2R setup is a "mini-chipless" engine...woth some shared competently from the R2R board (I surmise). The separate DSD512 chipless engine is a macro version of the former with no ties to the R2R engine and has all its own maxed out components, hence the higher speed and larger size. To me, that is the real deal. The former is nice, but the latter is a BEAST.
I have to admit that I'm still trying to find files on Roon on the SGM server. they don't sort by format....or even label, only by album or artist. with JRiver they were all sorted by format and label and I knew exactly where each one was after a year of using it. I could very quickly find and open any. with Roon often I need to open the file to see the format. so it's a long tedious process to figure out my favorites. so far I've just scratched the surface since I have to mostly stumble on them.
the dxd files I've really liked are mostly compilations of dxd from master tapes I think. one particular one is Diana Krall, 'Live in Paris'. I have that master tape. another has a number of amazing transfers of familiar analog recordings.
what I need to do is get the Challenge Classics native dxd files that Audiocrack has promoted so strongly. currently I only have the Quad versions. these are all native dxd mastered.
Hello Mike
Go to overview, show all albums, then click focus, scroll completely to the right and there you can filter for format and for label.
you can even stack filters.
Room is very mighty and rules big time.
It's simple as that ;)
Thank you for that. One more question though : what does "DAC-chipless" mean? From what I understand, the DSD bitstream is low-pass filtered using discrete parts; so what part is going through the "chip"?
What "chip"? There isn't one.
It means no ESS Sabre chip or Wolfson or Burr-Brown or Cirrus or Analog Devices or, or, or...DSD conversion is thru the discrete filter box that hs other chips in it. No all in one all singing all dancing , Jack of all trades Dac chip. Chipless means no use of a classic Dac chip.
Hello Mike
thank you. will try tonight. sounds easy.
Thank you for explaining. If I understand correctly, there is no DAC chip but there is an I/V converter chip. That would make sense.
I don't think there's an I/V converter chip either...
Doesn't to me ;) If there's no DAC chip there's not likely to be any I to convert to V. I/V converters are called for because so many DAC chips are current (I) output.
Well, posts #121 and #124 pointed to some chip in the DSD section. I have no idea what it does - that's what I'm trying to understand. My I/V converter assumption appears wrong.
Chances are what 'chip-less' means is really 'DAC chip-less' (just as wisnon suggests). So perhaps a logic device such as a flip-flop is being used as the DAC. And a flip-flop will be voltage out, hence no need to convert.
