do Yiu own the psvane 6ac tubes ?In the mean time, I am still searching for the Tesla EL51 with no luck![]()
Can anyone give me guidance on where the best setting for the volume control is? I have been experimenting between -5 to -7 db on the GA. That means the NAT peramp is about halfway for comfortable listening levels. I would imagine to some extent the settings are output tube dependent since different tubes will have different amounts of gain.
Thanks.
Looking for help. Just got a USB cable, using ROON. Lampi will not accept DSD512. Won't play anything above DSD128. Here is a picture of the back panel. It states it should render DSD512. Does anyone have any ideas?
I'm bummed because I wanted a DAC that accepted DSD512.
Spidif is only used for pcm files due to its limited bandwidth.
I am currently using the GEC Kt66 and the Psvane Acme 274b.
I do not have the Psvane 6ca7-tii.
I really like the 6CA7 t2 one of my favorites with the psvane acme 274b. Don’t care much for the Gold Lion KT 66 but have not tried the GEC’s from the 50’s. I’m also in the US but got mine from Tube Amp Doctor. They arrived here faster than my 274b Did from psvane in Canada.I did want to try the Psvane 6CA7 TII but noticed that Grant Fidelity is only selling singles. Are there any other good sources? TubeAmpDoctor is out of stock. The Chinese vendors give me pause....
I find the GEC KT66 and the ACME 274b have a good synergy
The Psvane 6ca7-II are excellent output tubes for the TRP and are more linear than the NOS GEC KT66 and still deliver that magic but I prefer the RK 5u4g, the Takatsuki 274b and the Shuguang GZ480 as matching rectifiers over the the ACME 274b
I found the best setting depends on the preamp, at least in part on its gain. With a PrimaLuna, it was around -27 dB, while with a Supratek -15 dB and the preamp gain knob set at half offers the best combination of SQ and volume control with the preamp. Lampi NA said to set the TRP at full volume, but I didn’t like the result. Someone here or elsewhere suggested setting it so the preamp volume knob runs between 10 & 2 o’clock, but at -15 dB, I don’t find need to go past 12 often. So I suggest experimenting with the pair to find the best SQ, given the volume level of what you play and like needs.
