Indeed. But these tele CG3 are Uber duber, hole in the pocket expensive… And you need 4 of them… At this stage, though, I also trust Ian and I am sure they sound stellar. Congrats. Do you have the SRS 551?
Use the siemens they good too,they come from the same productionIndeed. But these tele CG3 are Uber duber, hole in the pocket expensive… And you need 4 of them… At this stage, though, I also trust Ian and I am sure they sound stellar. Congrats. Do you have the SRS 551?
Not the 551Good work Ian. Now people have to find the srs551. I’m betting you have a stash
Not entirely true .Lorenz siemens valvo and telefunken all had different production sites and specs. It is true the siemens c3g and c3gs is the same production line and spec just one rated higher...which is why their tubes says s only on the box not the tube.Use the siemens they good too,they come from the same production
Product - BTB - Elektronik
C3g Poströhre - Pentode Verantwortlicher(EU): Antiquität Hersteller geschlossen,oder unbekanntbtb-elektronik.de
Which ones are you using?Eureka!!!
It works everyone! Now basking in the glow of the srs551s Nd listening to some good tunes
In 1952, Siemens&Halske (Berlin&München) began series production of the first European grid tube, the C3g, which was primarily used in long-distance telephony.Not entirely true .Lorenz siemens valvo and telefunken all had different production sites and specs. It is true the siemens c3g and c3gs is the same production line and spec just one rated higher...which is why their tubes says s only on the box not the tube.
For telefunken s is marked onto the tube itself and an old telefunken employee who sold the whole carton box told me ...siemens just tried to copy what the others were doing using normal c3g stock...whereas telefunken truly up not only the spec but the parts/design inside the tube.
That is why....if we know...we dont touch the siemens s tubes...and why some websites report the s as just being an uprated c3g. Siemens had to come up with the same part so as not to lost the German post business but was very very cheeky on how they did itinventive almost haha
Truth in there but not all the truth!
Hi StephanIn 1952, Siemens&Halske (Berlin&München) began series production of the first European grid tube, the C3g, which was primarily used in long-distance telephony.
production was outsourced when demand was too high. where Siemens is on it is not always Siemens inside. The same applies to Telefunken. the two companies had a strong working relationship on special tubes.
we don't want to argue, an excellent tube as a driver (triode mode) for 2a3/300b and f2a powertubes.
Highest quality (Gabl code )every tube have seriesnumber and mesurement protocoll.View attachment 113579
Hi Ian,,Hi Stephan
The tube was initially designed by Lorenz itt and the other just latched on. Siemens didn't design the first c3g I understand. The different brands agreed are not relabelled but rather each came from its own factory.
Ian
WoW $50,000 in tubesNot entirely true .Lorenz siemens valvo and telefunken all had different production sites and specs. It is true the siemens c3g and c3gs is the same production line and spec just one rated higher...which is why their tubes says s only on the box not the tube.
And that's not an expensive tube. The most expensive I have in stash and have seen is the 300b engraved base. About 10-15k us for a pair nowWoW $50,000 in tubes
You hit the lottery, but I am happy with what I currently have.
This is a crazy rare tube as well. Worth a cool 4800iusd for 1 tubeWoW $50,000 in tubes
