You people caught me on the hop! I had to quickly go away and burn a disc to try it out. Also, it's raining at the moment with a metal roof at the far end of the house, so it was played at maximum volume to pick it up clearly at this point.Frank, it would be great if you could post your results here. Once I get a mic preamp, I'll do some recording.
Hello all
I’m Art Noxon and I’m very pleased to be invited to work in the Expert position here and represent the audiophile version of room acoustics.
I believe I need to begin by apologizing in advance should I display anything but absolute neutrality towards all acoustic products and techniques. I will do my best to explain and support the appropriate application of any product or technique we are covering, but still, I do have my favorites…..
Where do we begin this adventure? I have selected a listening experience as the opening salvo. Audiophiles tend to want to listen first and talk second. It is the nature of the golden ear crowd. I will always assume I am addressing golden ears, even though there may be some technical people and collectors out there as well.
High end audio started for me in 1984, having just invented the TubeTrap. In the beginning I spent a lot of time trying to figure out why audiophiles got so excited about putting a pair of TubeTraps in the front corners of their listening room. Yes. I was pleased and proud, but being the hard core engineer that I am, I needed to measure, to quantify, what caused their thrill. I tried all the standard tests known then, which are the same ones known today; sine sweep, pink noise, RT-60s, narrow spectrum analysis, TEF waterfalls, and even Q changes of resonant modes.
What did I get? The best was about 1 dB adjustment in anything, usually less. Certainly not enough to warrant the pleasure those trapped corners gave the audiophile crowd. I published my findings (failure to find) in the AES and didn’t know what to do after that. In the mean time we had gotten so bored with reverb chamber testing of TubeTraps we tried to speed the process up and were getting very illuminating results using rapid short tone bursts. Not only in the chamber but in real rooms we were documenting changes upwards of 10 to 15 dB for rooms with and without TubeTraps in the corners.
Coincidently at this time, 1986, I was going to the SynAudCon meetings. Victor Peutz, from the Netherlands, showed up and presented the new/next wave of audio performance testing: Intelligibility. I couldn’t believe my ears. I realized right then and confirmed with him that our fast tone burst testing was actually a tonal intelligibility test. Much more has come to light since that first peek into the wonderful world of audio playback intelligibility, which turns out to be what really matters the most in hifi playback.
And so, here is the link to the MATT TEST for you to click on. Included here is a description of the MATT test, a training demo and a downloadable MP3. MATT means Musical Articulation Test Tones. This test is also on TRACK 19 of THE STEREOPHILE TEST CD 2 and many audiophiles have that reference CD. Do your own A/B test. Listen to the signal first on headphones and then listen to your audio system try to play it. We’ll talk about what you hear soon enough.
For now, report into the forum about what you heard……………………………… Arthur Noxon
No garbling, no matter where you go in the house with the Phillips volume maxed out?
Beautiful, boys!! I love it! The only trouble with that poor fellow's efforts is that his speakers are too big, mine are about half that size, I mean, I don't want my ear lobes resting on my shoulders ...I thought it was obvious that Frank was walking around the house with the small diameter speakers strapped on as headphones. It's a great way to really boost the direct to reverberant levels.![]()
it was so off-colour initially his wife had to go off into another room because it disturbed her. But a bit of fiddling brought the system back on song,
Key things were mechanically related: as people are well aware vibration control is very important, so an experiment he had tried of damping the catridge in the arm was doing the wrong thing: it was adding almost a reverb to the sound, if the recording had minimal echo it seemed to enhance the sound, but if the recording had plenty of such then it clashed with that intrinsic to the production: it was a distortion, pure and simple. So he removed that material, and luckily he had some quite sticky viscoelastic goo, better quality Blu-Tak, so to speak, so we smeared a very fine layer of that on so it filled the gap between the top of the cartridge and arm, tightened it down as firmly as we dared with the screws. In this case, better mechanical coupling of the cartridge to the arm, with the goo working to dissipate some of the vibration resonance. Much, much better sound.Don't be shy, Frank. What did you fiddle?
Tim
Did he put the roller blocks back under the Naim as soon as you left?
Now, now, no naughtiness: these are good friends, so no unpleasantness, please.If they were successfully driving his wife from the room, I'd guess yes.
Tim
When four people out of four decide that something sounds better one way than another that's pretty good consensus ...
Frank
Frank
The trouble, Art, is that some people here believe I have the intelligence of that tree!I really appreciate your finding value in my work. In the end, that is why I do it. What good would it be to explain one of nature's secrets, for example, to a tree?
