Yes, I own stocks, one pair of S5 (almost sold), and another one (Mk2) coming
But back to the MPod/stand etc,
Let me try, since the manufacture didn't find the time to do soto explain how these footers work and why they are anything but simple or economical.
Assuming this foot is similar to a QPod, then it is a multi-layer device were a “sandwich” is formed by laminating the stiff base layer to a damping layer and adding a third stiff constraining layer at the bottom. In the QPod case, Magico has double up on the "sandwich" and added copper and stainless steel to the mixture. When the system flexes during play, vibrations are channeled to the middle damper where they dissipate, preventing vibration from going thru the component to the floor and vice versa. I have 2 set of 3 QPods, one under my Cd player and one under the Preamp, and I can tell you that it is the most effective foot I have ever heard in my set up (I also tried the SP, which are actually more expensive).
Doesn't look or read remotely like a 10k product, but to each their own.
