Let’s dream about implementing a pair of speakers like the M9s.
The asking price of $750,000 is really only the beginning. To justify their stratospheric pricing the speakers obviously have to be capable of creating an accurate reproduction of either the recording venue or of the acoustic created by the recording engineer and of all the instruments that may be recorded. Given that it is capable of reproducing the entire sonic spectrum down to 18Hz and up to 50KHz the room in which it is placed needs to be:
- Big enough to support and not be overloaded by the lower frequencies
- Have a Resonance Time at the listening positions that match the equalisation of most recordings
- Have an ideal distribution of room nodes
- Offer the perfect distance relationship between speakers, walls, floor, ceiling and listening positions.
- Have a 4 part floor, with solid isolated foundation for both speakers and the equipment, while the balance of the floor is suspended and tuned to provide the correct RT for bass frequencies
Next, you need ancilliaries that have the same outstanding capabilities and sufficient power to drive the speakers to significant SPLs while maintaining huge power reserves. Things like cabling need to reflect the same capabilities as the speakers in terms of transparency, accuracy and ability to transmit the full frequency spectrum unaltered. All this equipment needs to be ideally positioned and installed, preferably in an acoustically and vibrationally isolated environment.
Sources of course need to be Worldclass....if we’re talking analog then we also need SoTA materials like 15 or 30 IPS tape and pristine vinyl. If we’re thinking digital, then the entire environment should be ultra low noise, with a single Fibre Optic feed powered by the very best DC sources.
Power to the room needs be properly engineered, with a dedicated supply from the power company, a purpose built consumer unit using RCCBs and MCBs designed for audio, specialised earthing using properly prepared and hydrated earthing pits with impedance monitoring
A Geothermal HVAC system ensures a beautifully even temperature year round, without the noise and vibration of typical AC.
So, anyone have a spare $3-4,000,000 they’d like to invest, plus enough building land?
