G'day maties,
Trust all are keeping well and you're all enjoying those fine tunes!
I just had an outstanding audition on the Ren15a's and must report, as I've titled these elsewhere as "the formidable Ren15a." I'll explain the formidable in my closing comments.
Why I'm so excited about this particular setup is that the room is nearly exactly as ours! An open plan living room design, which includes a full space of approx. 35ft L × 45ft wide & 10ft high ceilings. This particular room has a dedicated space just for the audio system (exactly as ours), then approx 10ft after the dinning area along with the kitchen towards the back, and extra office space towards the far right. Whereas, with our room it's nearly similar, system in dedicated space alongside long wall facing width, then about 15ft after the dinning area, with office space on far left, and our kitchen located on the far right.
The beauty of these two very similar room layouts, is the open plan that allows the system to breathe freely and not get congested in any way whatsoever. No overhang, no boom, nothing echoes, just crystal clear tunes in full spec.
His system comprises:
Preamp- VAC pre
Power amps- VAC 200w monoblocks
Digital gear- Esoteric K05XS
Analog rig, TT- Rega RP10 (with Sound Smith cart).
Phono-preamp: Allnic (tube phonostage).
Speakers: ML Ren15a
Cables & interconnects- full loom of Nordost Frey2 and Tyr2 cables.
So it was very exciting to audition this, since nearly every aspect of the system was pretty much similar to mine! The only difference being the ML hybrid stats. To cut a long long story short... the main reason was the owner was wanting this particular CD (attached pic) and it wasn't available any longer. Merely because it's on a FIM label, and since FIM closed up, these ones are very rare. So he got in touch and the rest is history in the making.
I took along this CD and the opening track on Bolera was superb! Then came the second track and even better with superb bass lines. Those first notes on the percussion marching tune then later picks up in full swing, followed by some serious bass lines on track 2, is just outstanding!
Obviously the LF is deeper than the stat panel on the CLX's but both provide plenty of LF detail.
The controls on the back panel of the Ren15a's do help by a significant margin, to fine/tune balance out the LF response. Otherwise the LF thump can be overbearing, and that is something you don't want especially in an open plan layout.
Later during the evening, he made a trip back to our place and as you can tell from the time, left only around 4am. We were quite mesmerised by the overall presentation of the CLX's without subs or any other added LF devices... although the bass wasn't as deep as the dual 15inch drivers in the Ren15a's (Obviously not) the overall speed and agility in the bass was what kept us fully engaged. When a particular LF note is called upon, it hammers down well deep enough with precision and bullet speed. This is something I miss from large cones, the physics is obviously different. OTOH, smaller drivers like those with 8inch towers would be able to deliver better speed. When tuned in correctly with the perfect blend of crossover units and DSP, it actually sounds marvellous! Why I term them as "formidable" is simply due to the fact that the Ren15a's are capable of some serious wallop! In just about the right room size, they are truly awesome. You really don't require the Neoliths unless you had a very large room. So I would be looking at something much larger than 40ft L & 50ft going across, probably 10ft ceilings would be fine but definitely much larger space. The Neoliths need serious space to breathe, I seriously don't think dedicated listening rooms would do it, rather larger halls and open plans suit these huge stats. The ones I audition in Spore driven with CJ's ART150 are setup in this way, and they're awe-inspiring.
So we really enjoyed both listening sessions, I was in awe of those fine VAC monoblocks. They have a cool feature with their output tubes. If one's going weak or bad, that particular tube LED lights up, stating it's ready for a change. That's extra circuitry I guess that CJ simply doesn't want to divulge in. They always keep their circuits as simple as possible using the highest quality parts available. I guess they have their reasons.
Anyway, it was a real pleasure to experience another ML stat system placed in an open plan living room with perfect acoustic balance, where the musical presence is fully engaging and you are totally immersed in the performance. I guess that's why I was over there till about 9pm, and he spent upto 4am over here.
Since the rest of the household was asleep, we really didn't even open up the levels that much, goes to show you can still enjoy the music with a perfect sense of balance, just like focusing a camera lense.
Cheers maties, a big woofty woof!!!
Enjoy those fine tunes!
RJ
