their avantgarde speakers were even better!This room was in my top 10 group at HE Munich
Matt
sounded big and glorious when i was there, the walls were shaking when playing this trackI have heard this model can’t say what revision many times
I love line source sound
but this speaker never makes me stay to hear them long
Did you make a YT?their avantgarde speakers were even better!
There is some info on the sub here: https://www.fmacoustics.com/news/Very strange. You can't find any detailed info on these speakers at all on the FM website! It's like a child the parents forgot to put in the car for a family road trip.
that room was not the Wadax room but the room is Fono acoustica room. Their were 5 Wadax set ups at the show . The Wadax room was with Wilson Benesch and ARC electronics.have not seen R Koda himself, but Wadax is using R Koda gear, so I was excited to see see the set up as such.
What speakers are these please?
Aren't these designed by a very nice Hungarian chap, exhibiting on the ground floor (H)?
Any info on this brand will be appreciated..
From what I understood, there are two separate boxes, the Xover depends on aligning the top & bottom box. I don't remember if there is an electrical or mechanical xover, probably a combo of both. The drive units were designed & produced by him, both the 12'' (I think) wide-range woofer and the mini-horn / waveguide on the tweeter. The system goes down to ¬30Hz in a room.
It sounded quite good in that small room.
Many thanks for this effort, Totaldac.Many large rooms have been recorded by Totaldac during the High End show 2022 using high quality microphones.
This allows you to listen to many rooms using a given headphone, and all these rooms have been recorded using the same equipment, so you can compare and make your own opinion.
Note that a real saxophone has also been recorded, giving you an idea of the quality of the recording system.
The volume is not normalised because absolutely no processing has been done to audio recording, so the volume of your headphone should be adjusted for each track.
Depending on the time of the day, some rooms are full of people and some are empty, this changes the reverberation time inside the rooms.
Exhibitors can send me one line describing their system, with the start time in the video, I will add it in comments.
Please send an e-mail via the web site https://www.totaldac.com
