Theaudiogeek,@Johan K - The installation went very well. Had my buddy help me yesterday evening setting it up. I had to take the table down since I got the arm board extended with incorrect length (I have a 12" TA-7000 tonearm). All is good. ASCONA is a fine piece of engineering and a behemoth. The sound quality is much better than Montana. I am thrilled with this table.
That is a very good looking turntable! It looks just massive! And I can see you got the DS Audio Ionizer.. that’s cool. I haven’t got that one yet myself, but I will probably later this year.
Regarding taking it down again… The same happend to me with my 12” arm. At the moment I was alone - and had to slide the TT over the edge of the platform to get to the holes underneeth to be able to correct the length of the armbase… and to do that alone with one arm holding the TT to not fall over the edge, and try to screw through those little tiny holes from underneeth with your other arm was a sweaty task - I tell you?… but I did manage. Puuussst !!
Nice that you immediately could hear the difference between the Montana and the Ascona - that’s cool. I heard it too as soon as I started the platter. It was a complete silence rigth after startup - just some noise when the platter reved up, but when it came up to speed there was a total silence. With both the Typhoon and the Montana I could always hear the motors spinning, and non of them was completely quiet when I had them, but the Ascona is.
I take off my hat for you, and congratulations to your new turntable. It’s Awesome - Enjoy!
All the best
/ Johan
