Recommended ICs with Shunyata Power Cables
Bluedog
37
16
140
70
Boston
For those of you that run Shunyata power in your rig, what iCs do you find gives the best results? I thought I heard on a previous post that some prefer MIT ICs. I've heard others recommend the Cardas Clear Rev1. I'm currently using Shunyata Alpha RCAs through-out with nice results. Thoughts? Experiences?
sbnx
1,208
1,361
290
I use MIT cables with Shunyata power
tima
5,866
6,940
1,400
the Upper Midwest
The choice of interconnects is more likely a function of the components they will connect. While power cords play some role in that choice I don't think they drive it. That said, what do you think is the relation between the choice of each? IAre there some specs or measurements that provide guidance? Or is it the resulting performance, most particularly the resulting sound what determines selection? I suspect an answer to your question is of little help without laying out a full system complement.
FWIW, a lot of Shunyata power cord users chose Shunyata interconnects. I used that combination for several years. The power cords continue to move forward with two things: maximizing current delivery (DTCD) and noise reduction via filtering. The ICs and SCs are oriented to avoiding or reducing electrical characteristics or properties of cables that can cause distortion or interference of the signal, such as dielectric energy absorption and release.
