In ported speakers the mid driver and bass drivers aren't playing the same frequencies. When you mix bass towers and subwoofers there will be some overlap. Also the mid and bass in a speaker meet at a much smaller point where even if it could be slightly less optimal because of the nature of making a speaker, the range will be countable in inches. When trying to cross bass and subwoofers you're in a zone where you might be talking about tens of feet. The merger is on very long wavelengths. You can try to cross them really steep but I've never seen it done without sounding like two separate speaker systems, and one being only low bass. That is probably due to the fact that no matter how low a speaker plays in measurements, the response is a bit choppy so you're better to smooth it out a little by crossing at a rate that isn't overly steep.
I don't mean to make ported speakers sound like they're bad, they are not. They do simply sound different, and that's the concern. I'm not entirely opposed to mixing ported subwoofers with sealed towers, but we aren't discussing "needs" are we?
