A good read if you haven’t seen this,especially the comments.
https://www.psaudio.com/pauls-posts/missing-the-point/
I hope you are not being shy about your preferences in the looks department, i just don’t see you as a guy that could live with two big boring cabinets in yourFollowing up on Folsom’s communications on my behalf with Nathan Funk of Funk Audio, a subwoofer specialist in Canada, I just had a long and very interesting telephone conversation with Nathan. Nathan was very patient as I asked my questions, and very generous with his time and his answers.
It turns out that Nathan not only cuts, fabricates and finishes his own 1.5” thick Baltic birch cabinets, and can also work with exotic non-wood materials such as Corian and aluminum, but Nathan also fabricates his own 18”, 21” and 24” drivers!
I wrote to Nathan:
My full range speakers employ woofer columns consisting of eight 8” drivers in a vertical array, which are rated at approximately -3dB at 16 Hz. The subwoofer system would focus on the frequency range of below 10 Hz to approximately 25 Hz.
I would use Class AB solid-state amplifiers (Parasound JC1s) to drive the subwoofers. I would use two Wilson Watch Controllers to implement low-pass, slope, phase adjustment and level functions.
1) Nathan advises that the four or more subwoofers “swarm“ concept works best when the subwoofers can be placed approximately equidistant from the listening position. My listening room will not allow for this because my listening position will be only a few feet in front of the rear wall.
Because my listening chair is not closer to the halfway point or even to the one-third point in the room Nathan thinks that the swarm concept is not the right solution for the layout of my listening space.
2) Nathan says that the ideal cabinet size for a given driver size is a function of the components and of the electrical and acoustic characteristics of the driver. It is not simply the case that the bigger the box, the lower the low frequency response.
3) I expressed concern that a 21 inch driver might be “slower” sounding and lower in resolution and manifest greater “bloat” than an 18 inch driver or a 15 inch driver. I said that in audiophile land we tend to think that, all else being equal, the smaller the driver the “faster” the bass and the higher the resolution and the greater the texture we will hear in those low frequencies.
Nathan suggested that it is just not the case that one can assume that a larger driver is going to be higher in distortion and bloat and lower in resolution than a smaller driver. He says meaured
distortion and perceived resolution are functions of all the factors, including the driver surface material as well as the size and quality of the motor.
Because my intention for the subwoofer system is to reproduce very low frequency ambient acoustic information of low amplitude, Nathan agreed that I do not really have to worry about distortion at high SPLs. Nathan recommended his 21 inch driver.
But I said that I had trouble getting comfortable with the idea that a driver that large could be low in distortion. I really do find it very interesting, and possibly very telling, that Wilson Audio has evolved its top-of-the-line subwoofer from 18 inch to 15 inch to 12 inch drivers.
We decided to focus on his 18 inch driver using his highest quality, heaviest motor assembly.
4) Rightly or wrongly, I said that I like the idea of low frequencies not coming out of merely a box sitting on the floor. I expressed my view is that I like the idea of a fairly tall driver system. Using two 18 inch drivers Nathan recommends a cabinet height of about 48 to 50 inches.
5) We discussed a dual-opposed configuration of drivers rather than one driver on top of the other, but given the low amplitude the subwoofer system is likely to have to deal with Nathan sees no major benefit in the dual-opposed arrangement to cancel opposing forces.
6) For the same reason Nathan sees no advantage in putting each individual driver in its own enclosure, and then bolting together or simply resting on footers one self-contained enclosure on top of the other self-contained enclosure.
One advantage of a single 18 inch driver in each of four separate enclosures is that I would have the flexibility to experiment with a limited swarm concept
by being able to spread the subwoofers around in four different locations in the front of the room (keeping each box fairly equidistant from the listening position) or double them up, one box on top of another.
7) Nathan mentioned that he has made a custom enclosure for a customer consisting of 1 inch or 1.5 inch thick Baltic Birch on the inside covered on all sides by 1/2 inch aluminum. The idea of the wood is to dampen any resonance or ringing from the exterior aluminum box. So this would be a box in a box: a Baltic birch box inside an aluminum box.
Nathan said he didn’t know a priori whether greater aluminum ringing dampening could be achieved if the aluminum box were the inside material and the Baltic birch were the outside box, or if, as he did it before, he built a wood box inside an aluminum box.
listening room, no matter how low they go.
You like pretty things, nothing wrong with that !![]()
Ron,
Good. So are you thinking about 4 individual cabinets as a swarm or 2 dual 18’s in a single cabinet?
Btw the fastest bass and most impressive presentation I ever heard was a single Hartley 24 that was slot loaded into the crawl space of the home.
My dual 16 and the 18 can be impressive too.
The dual 16 I had finished in Teak wood to match my satellites...I consider it not just a box,but a very nice piece of furniture. My Velodyne in black stands out like a sore thumb compared.
I think you will be playing more classical,Frederick Fennell and maybe even great pipe organ recordings.![]()
Well i think the Pendragons are beautiful , one of Gryphons strong suits is good looks and they say black makes you look slimmer.No speaker does much for me aesthetically. Maybe the Cessaros in audioquattr’s color are interesting-looking.
If I want big subwoofers in a big box there is only so much you can do with that aesthetically. With Wilson Audio I could match one of their automotive colors to the color of the Pendragon cabinets. I would’ve liked the Pendragons in a light great or a medium gray color, but they came in black or near-black.
Depending on whether Nathan uses wood or aluminum as the exterior material, I’m sure he could come up with a nice-looking dark gray or charcoal or black finish of some kind to match the Pendragons.
