Aren't you using some NOS tubes in your CAT?
Myles, that's correct. Sourced from Uncle Kevin
However, according to Ken Stevens ( who i think knows a thing or two about these things), it is actually impossible to get an all tube phono stage or line stage to have no noise whatsoever. The noise I hear is a low residual noise ( I suspect from the tubes themselves, as it sounds like tube rush
Also, this from Ralph ( Atmasphere):
"all active circuitry makes noise. Transformers are passive devices and don't make noise, but there is a price paid for their use as well. IOW there is no free lunch.
IOW there is no curse
I see the words 'dead silent' used a lot. I know that is not the case; as I mentioned before different people have different tolerances for noise.
For those who think their all-tube system is dead silent on phono try this little test. Leave the tonearm on the tonearm rest. Set the source to phono and turn up the volume all the way. If you can then say that even with your ear pressed to the drivers of your loudspeakers that there is no hiss whatsoever then you have a good case for 'dead silent'. I think you will find though that you have no need to press your ear to the drivers- the noise will be quite evident."
I suspect Ralph's test should be an eye/ear opener to all of those who are claiming their system is dead silent.
