The box and cone cult guys give everyone else a hard time… wow that even looks stupid as I write it… insert horn… and that’s in very a non threatening way lol. The differences between us become harder barriers the more we choose to make them.
As a guy with a few horn speakers who’s also got panels (Maggie 20.7) and box and cones (Harbeth 40.2) I live with and also appreciate the differences. But I don’t see the speaker type I choose defining who I am but rather the nature of the differences help give me understanding perhaps where I am in the development of my aims.
Is the state of the industry actually just in senescence. The majority of us have matured (kind of
) and the industry has matured along with us. We’ve got more differentiated, more defined in who we are and what we do. But maturing isn’t always about being across the board better but having simply different aims.
Our chosen speaker types or amp types or source types aren’t just about an idea, they function to create a way of perceiving and so being able to identify from your choices the way you perceive is an even greater asset perhaps.
So is the pursuit moving towards an imminent end (I don’t think so) or perhaps a change point in its life cycle (I feel this could possibly be the case). In terms of identifying the most essential way the industry has changed I’d suggest it’s mostly for me about recognising what direction it has taken since beginning and then perhaps what phase it is in. In terms of direction of the system I’d suggest most systems (talking big systems like movements, civilisation and cultivation, ecological systems, planetary systems) either tend to move from complexity to simplicity or vice versa from simplicity towards complexity and then also in terms of expanding or in contracting. These are process phases that seem to follow and balance each other in terms of greater life cycles much like a Möbius.
I figure the early audio gear like Forest’s amplifier back in the start of the 20th century started simple as did the speaker systems and the first sources. It all started simpler and has moved through time to increasing complexity. I guess if you’re chasing the sonically correct dragon and chasing more perfect measurements and greater linearity and greater extension breaking things into more and more parts and ever greater specialisation so more drivers, more complex crossovers, a greater range of components within the system, biamping, chasing more bits resolution, doing more measurements etc is a way to try and perfect all the parts.
In terms of identifying the most essential way the industry has changed I’d suggest it’s mostly for me about looking at the whole system in its history and defining it’s overall movement. Most systems tend to move from complexity to simplicity or vice versa. These are two phases that follow and balance each other as a Möbius. I figure the first audio gear started simple. It all started simpler and has moved through time to increasing complexity. (Edit for accidental cut and paste of a paragraph twice, shouldn’t post so early in the day
The greater movement of the 20th century has been completely this. It is the overwhelming trend to complexity and fragmentation… but then when you’ve broken things down as far as you can go bringing this all back into a mutual undifferentiated wholeness and through synthesis into seamless sonic coherence becomes increasingly problematic… what tends to gets lost in the chase for the fragmention of some idealised sonics and in all the parts of the sound can just be the easy simple whole connection to music which had been a fundamental core of the initial purpose of the movement itself. This may well be mirrored in our individual journeys as well since we are also part of this movement.
So I’ll take a punt and propose we are perhaps not at the end but merely halfway along in the journey. The move to complexity has perhaps just been the outward bound leg of the audio journey but the return back to simplicity may be the homeward return. The hobby and the attached industry may even need to return to simpler ways. Time will tell.
In greater ways this reflects in culture as a whole. In life over the last century we also have been moving (exponentially racing) towards increasing complexity and increasing fragmentation and with more differentiation between many parts and as a result of more parts we increase the number of recognisable boundaries. Perhaps finding the ways back to simple wholeness and togetherness is about dissolving boundaries and moving back towards unity. In our systems, in our selves and even with each other.
