OK. I can relate to that. My system is on a suspended floor where I had all the floor joists doubled up when I had the IRS-V installed. Should I have had them tripled or quadrupled?? There is a limit to the number of beams you can add, or should I have just added another 600 sq ft room to the house on a slab? Should I have moved? Some things become impractical.
On long sustained extremely deep organ notes, the floor starts to do sympathetic vibrations you can feel when standing or sitting in an uncushioned chair, but it takes time for enough energy to be built up to make these sympathetic vibrations. This does not happen with bass drum, tympani or bass guitar or even deep tuba notes. The long sustained deepest organ notes is the only instance where I have any room issues, but since it is the woofer cones moving the air, not the cabinet vibrating causing the effect. I don't see how stillpoints will do any better than the original Wilson spikes to minimize the problem.
I find the spikes transfer the energy to the floor and cause it to vibrate. I use Herbies Audio Lab decoupling gliders for this reason.
