Thank god.CC’s have nickle plating too.
I mean it certainly isn’t rhodium...
I took a short video, maybe I'll post it. I am the owner of the Shunyata Venom HC v2s. in my system these were better than the Ching Cheng at least in terms of bass performance. I have 10AWG in wall and a long enough run that I think having 10AWG power cords to my monoblocks make a difference (and I think the CC are 14AWG).
The Shunyata are relatively inexpensive power cords (relative to Shunyatas other offerings) and I just wanted to try something with 10AWG to see if it made a difference (and it did) but I also guessed that it might color the sound in some way (possibly due to nickel coating on the prongs) especially since Shunyata needs a reason to sell more expensive power cords.
In Peter's system there was deeper bass with the Venoms but I found it somewhat dark overall and lacking air - so somewhat less engaging than the CCs. It was also a VERY quick comparison and hardly representative of a Ching Cheng vs Shunyata shootout. But hey, the CCs did sound better and were still cheaper!
So did Al and Peter listen to the CC at Ian's compared to his Shunyata?
Again, I feel compelled out of fairness to Shunyata that you're basing your negative impressions of a company on their entry level products. Their NR power cords on my power hungry amps did not work well and that is not entirely surprising. I think the NR power cords did work well on the DAC (there certainly wasn't anything wrong) but we hardly gave it much of a chance and for the purposes of you getting to hear my CH L1 preamp without other variables we just removed it.
The 10AWG cables we tried in your system were the cheapest cables Shunyata makes and to be fair it did improve the bass in my system (and perhaps arguably in yours). I wouldn't want to judge Magico speakers based on their A1s (that's just an example, I haven't heard them). When a company makes products that cost thousands of dollars and you choose to try their entry level product that costs $250 I'm not sure it's fair to judge their technology and research and development based on that.
Fair enough. But shouldn't even their entry level products not sound worse than a stock cord?
I run 4 of them with my MBL 9011 amps, sounds great. I would call them high powered, but maybe it’s just my delusion of grandeur flaring up againI am in agreement with both Peter and Floyd. I think the CC's are musically right and pretty much unbeatable, except for components that really need to move current such as high powered amps. The CC's are on all my gear except for the Soulutions which use some custom Furutech DPS 4.1's. . It's a very good combination that maximize the benefits of each PC.
CC is basically lame. Can't find one thing fancy about it. Your electronic is on your own no helping. If you cannot use CC for high power amp why not try the same cable you use in your wall for powering amplification.
The CC are good to probably about 15a, that's up to possibly 900wpc rms. Few amplifiers can exceed the CC ability to deliver. Bigger awg is mostly opinion based.
... the bass quality ... was more extended and tighter with your [Shunyata] cords...
But your preference does not really support a conclusion that CC “beats” what, from a power delivery perspective, would appear to be a better engineered alternative. (“ a $25 cheap Chinese power cord beats a highly developed and researched power cord costing 10 times as much…”).
I think it may be more accurate to say that in your system you prefer a tweak which apparently limits the energy available to the amp because the resulting bass seems less hi-fi to you.
