Peter, you have a very elegant and wonderful arrangement of equipment and room. Thanks for sharing!
Along with the switch in phono amps, I have just decided to trade in my single-ended Transparent REF XL from phono to pre for the balanced version. The XOno sounded best with a single-ended output cable while the XP-25 sounds better with a balanced output cable to the XP-20. Unfortunately, the upgrade costs about the same as the different phono amps. I guess what they same about cables being like another component is true in that sense.
Hi Peter,
I've already expressed my admiration of your entire set-up in your vibraplane thread but I just can't help doing it again here. It looks very well thought out and I'm sure you are reaping the rewards for all that hard work and attention to detail. Good Job!
I would never sell those Minis on looks alone compared to the Qs, Peter- just gorgeous.
Keith, I fully agree, especially when compared to the Q1. I do think the Q3 as a floor stander is better. Now that Magico has the in-house capabilities of curved cabinets and baffles, they could attempt to replicate the curves of the Mini in an all aluminum enclosure, including the base. That would be interesting. But they are moving away from the one-off designs, except for the Ulitmate.
Along with the switch in phono amps, I have just decided to trade in my single-ended Transparent REF XL from phono to pre for the balanced version. The XOno sounded best with a single-ended output cable while the XP-25 sounds better with a balanced output cable to the XP-20. Unfortunately, the upgrade costs about the same as the different phono amps. I guess what they say about cables being like another component is true in that sense.
Since you were last here, fine adjustment of VTA, the XP-25 and the balanced cable have definitely improved the sound. I try to make slow and deliberate changes when they contribute to greater musical enjoyment. I'd love to share some listening time with anyone who finds himself in the Boston area.
I do not think the Q-series lack of curves, or rather, the "boxy look", has anything to do with capability... The Q3 does have curves on the front baffle. Seems to me more like a design decision instead...
alexandre
Peter, I'm curious, what kind of fine adjustments to VTA are you talking about regarding the SME V-12?
I thought I had read somewhere that Magico could not build curved cabinet walls when the Q5 first came out. They could mill a think baffle into a curved surface though. The curved sidewalls was described as a new capability with the introduction of the S5.
How about a curved baffle of the Q AND a curved sidewall of the S? We shall see what the future brings.
I did this demo on a fellow member's system with two of my LPs. He was really surprised at how much the sound changed and how much more natural the music sounded. In another experiment, this gentleman asked me to shut my eyes and tell him when the VTA sounded best as he adjusted it up and down on his VPI table/arm. When I said stop, he measured and told me that the setting was extremely close to the theoretical 92 degrees that he had previously calculated. I think that was a coincidence for that particular LP because I have found that the same thickness records have different ideal SRAs. 92 is just a close compromise and if you don't have a way to do the math or capability to see the stylus, how do you know what the angle is? It is much more accurate to set it by ear. You just have to train yourself to know what to listen for.
