I will see what I can listen to on Qobuz and see what I can suggest...then maybe, just maybe I have it on vinyl (I have 2 or 3 versions but not sure what/who did them).I have that. I was not impressed at all. Have you heard it?
Hi Peter,
Tone is pretty natural through the slower/less busy parts and tympani's sound very good but the overall presentation is somewhat lightweight and gets a bit congested through the full bore parts. This could of course be the recording as there is certainly compression on the recording to some degree as well as the medium (I find big classical works better with digital somehow...with the exception of Die Walkurie on Decca from 1965 conducted by Solti). At least from this recording it seems that middle dynamics are good and instrument tones seem pretty natural. To tell if the dynamics are really scaling as they should would require to hear this recording on another system, possibly with horns, to see if you are getting everything out of it or not. Have you ever heard this piece live to get a conception of how much impact could be missing?
Yes, there is quite severe dynamic compression in the loud parts. I have heard this in person on Peter's system, and the dynamics then are much better; it's not even close.
One caveat: I have not yet heard this recording in his current system set-up with all the changes to power etc., but I would be surprised if hearing it there in person I would experience the steep drop in dynamic performance, compared to what I have heard in his system on previous occasions, that I hear on the video.
Videos don't always work at even the minimal level, that seems obvious.
I didn't see how he made the recording. If it was with a phone that is probably fine for simpler music but could easily overload something that doesn't have controllable gain. With my Tascam DR-100MKIII there are a lot of ways to expand the dynamic range and control gain so capturing something with a huge dynamic range is possible...but at 24/96 it is a huge file and not easy to share.
Thanks Peter, is this GC or the MSS. Separately I was blind tested on a video between the two carts and chose GC for better nuance though only one record tested, with cello and piano. It will be interesting to see if you blind test us if it holds true in your system too
Hi Peter,
It sounds great, Peter! You are doing more than anyone else to suggest, if not to prove, the efficacy of Magico speakers + Pass Labs amplification.
Does the Pope shit in the woods?So, are videos then useful or not.
Hi Peter. If I may say, this Holst by Mehta record you have does not do your system justice. If you try one by Solti of the same label (not expensive either) you will get more clarity to the sound and you will hear each group of instrument plays more distinctively, better group instrument separation in the orchestra. The inter play from one group of instrument to another also pull you into music more.Here is a video I made a while ago trying to capture timpani and orchestral scale from my small room and small speakers. I made this right after I started using my Ching Cheng power cords on my amps and replaced the IEC connector on the JPS Labs cable with Hubbell industrial outlets. In room, the sound really improved. The video does not quite capture it, but one does get a hint of the impact from the drums and overall dynamics.
I have also happily discovered that my twenty year old headphone amp, a HeadRoom, can be hooked up to my iMac and used with my Sennheiser HD580 headphones. The combination actually improves the sound of these videos a fair amount, especially in the bass. The amp also allows me to lower the output from the computer and increase the volume from the amp for a cleaner sound.
The video may be restricted in some locations due to copy writed material. Holst Planets, Uranus, Zubin Mehta, Decca:
On Tuesday I had the pleasure to listen again to Peter's system. After a nice dinner at a favorite restaurant (outdoors, of course), we began the session with Frans Helmerson playing a Hindemith cello sonata (Peter earlier posted a video of the same LP where Helmerson plays Crumb). What struck me was the immediacy of dynamic expression, and the immediacy of the energy, emerging from a silent background (some surface noise notwithstanding) that filled the room. It was a riveting, dramatic performance by the cellist that came through in a very effective manner through Peter's system. I was so pleased with the experience that I asked Peter to play the Crumb as well.
Peter played the LP with the new Gran Cru cartridge on the 3012R tonearm, and apart from a brief comparison with the other arm/cartridge, that is what we mostly listened with during the remainder of the evening.
Next up was Scheherazade in the version with Mehta conducting the LA Philharmonic. We heard the first and the wild fourth movement. The music had the weight that I remembered from last time, but I also noticed that the solo violin sounded special. In recent times I have found that the playback of solo violin on digital in many cases now rivals vinyl in tone, and I did not perceive an inherent advantage of the analog medium also on this instrument anymore, which was quite remarkable. In fact, sometimes I preferred violin on digital. Yet two days ago I heard a rare realism that went beyond the usual quality of violin sounds from either vinyl playback or digital. Now, with all things sorted out in Peters system to the level that they are, and on this particular recording, the solo violin sounded just stunning in the naturalness of its texture from strings and resonances of the wooden body. Analog had again created an edge for itself; I have yet to hear such realism on solo violin tone from digital (admittedly, I have not heard this instrument on the top of the crop of digital). By the way, nothing of this realism on violin comes through on any system videos, including Peter's own (no wonder, since the YouTube medium is not just digital, but data-compressed digital).
Apart from the violin tone, all else sounded very realistic and with a depth of color rarely heard; also massed strings were excellent. Brass had a depth and weight of tone that was captivating. Separation of instruments and instrument groups was outstanding. Also here, on this orchestral piece, the immediacy of dynamic expression and of energy was remarkable.
Then it struck me what must have contributed to make this pervasive sense of tonal naturalness and of immediacy of energy from a silent background possible. While I cannot make an absolute pronouncement, this is quite possibly the system with the lowest noise -- both electronic noise and acoustic noise combined -- that I have heard so far. And all this achieved without fancy audiophile power treatment, just with apparently getting the basics of power right. Peter's system was nothing like this until now, but the low noise rendition is spectacular.
Holst's Seven Part Song for female choir and instrumental ensemble also sounded excellent. The voice of the solo singer had remarkable articulation, intelligibility and again, immediacy. It was a common theme.
We also played two songs from Art Pepper plus Eleven. It sounded very good and dynamic, and the tone of Art Pepper's alto sax was great, but here I was missing a bit of color on the ensemble brass that I hear on CD. But that must be just the LP mastering/pressing; I have heard other pressings and they sound different in many ways. My two CD masterings also sound different from one another. The walking bass lines sounded clear as always; now I was pleased though that my system finally, with the latest improvements, can render those bass lines with similar clarity (I checked again afterwards).
As an aside, while I have heard dynamic compression on orchestral LPs, the Mehta/LA Phil Scheherazade is one of those not so common 33 rpm LPs of large-scale orchestral music where also the macro-dynamic range is excellent.
I am pretty much finished with my system for now and as the weather cools this Fall, I think I will spend money on records and listening for pleasure. It has been a year of some pretty radical changes.
That was also my favourite line in the whole of Peter’s post Tim. A great resolve to cap a fine cycle of change. Good to go into life’s autumn with things sorted and the music playing. A perfect resolve in fact.Ah .... a fine notion. What I call 'The Listening Seasons' approach.
Dear Peter,Thank you Al. I'm glad you enjoyed the evening and were able to hear the improvements since last time. That new Grand Cru on the 3012R is a great combination. Yes, the Scheherazade with Mehta is an excellent recording and that 4th movement has a lot going on. It is a real test for natural resolution of a system.
I think I had made the changes to the power delivery just before the last time you visited, but both the Hubble outlets and Ching Cheng power cords on the amps were fresh with very little break in. I'm told the CC power cords don't need break in like so many other cords, but I have noticed that the sound improved in terms of dynamics after a while, so perhaps it was more the new outlets, but I can't be sure. I found our discussion about power delivery and specifically power cords quite interesting in light of our recent audition with new power cords from Shunyata which have garnered much praise from our Boston Group.
I highlighted one section of your post which summarizes my new approach to my system/room. I have found that simpler is better. Removing the Furutech IECs and essentially just plugging my amps into the wall with the new Hubble outlets improved the sense of energy and drama inherent in the recordings. This came with no negative effects. I suspect, however, that it is system context dependent and also very subjective. Regardless, I am pleased with my current, more simple approach, and I have no interest in experimenting more with power cords.
The other changes not discussed yet were continued fine tuning of my room acoustic. I removed the last absorption panel from the room. It was a 2' X 2' panel hung on the wall 14" behind the listening seat. I had followed the conventional wisdom of absorbing the reflection so close behind the listener. Like the other panels and tubes, it added too much dampening. I also opened the wooden louvers slightly on the two rear windows livening up the room a bit.
After discussing our appreciation for Frans Helmerson's cello playing, I ordered three more of his recordings and then came across some more LPs to buy. I am pretty much finished with my system for now and as the weather cools this Fall, I think I will spend money on records and listening for pleasure. It has been a year of some pretty radical changes.
Another great post from Tang.![]()
More on Scheherazade. Listen to the woodwind in Peter's video. Also the sound of each group of instrument during inter play. It is more intrinsically distinct and differentiated because there is no whitish sound that can be heard like from other videos of the same song. The woodwind sounds more hollowly dimensional like in the hall not just sound that make you realize what instrument is playing. Each woodwind can be better sensed in different location of the orchestra. Once the sound of each group of instrument is more differentiate less homogenous, the swing from one group of instrument to another by the conductor make listener follow the movement and enjoy how the conductor manure the play more. Excellent sound you have Peter. Excellent transparency too.It's not new music for anyone certainly, but Bonzo may enjoy this, or not:
