@Mgrif104
You have a very good point .
@Jeffy as does Jeffy.
The competator server needs to be set up optimally. Preferably by a manufacturer rep. That way the control settings as well as the platform and isolation are optimized. Ted would need to show be went to extreme detail in configuring the software, placing the unit and optimally cabling the unit to the DAC. And, more than one DAC should be used. Some DAC optimize certain inputs.
Ted is working for his paycheck. I respect that. I assume his equipment is as good as anyone elses.
Ted seemed to say his server is the same as anyone elses, untill the Active EM cells are switched on. I would be most interested in having these cells as stand alone I could use with any of my equipment. I think he has a 120 volt power filter you plug in based on this technology. That would of course be a filter before the power supply. Not sure if what he has in the server is before or after the filter.
I might be more interested to hear his 120 volt power filter head to head with a Torus and a Audioquest. More easy to set up and test. A server has so many variables.
