What an excellent report, Emile. Thank you. Much appreciated. I had to finally register here, so I can post.
Interesting that you start your discussion talking about glare. I have noticed that certain type of network injected noise could be perceived as glare. This is typically a digital curtain between you and the music. In some cases it is something that people may like, even prefer. It’s also interesting what happens when this digital curtain / glare disappears. All of a sudden you realize what the instruments really sound like, but one may be too attached to the glare-y sound and may even prefer it. It is indeed a way to tweak your system.
One of my takeaways from Emile’s report is how dependent the network tweaking is on the local environment. It’s very important to keep in mind the context of his tests. And people should be careful how they read his report. He did not say that the etherREGEN is better than the SOTM. He said that the etherREGEN “was initially disappointing” but in a very specific scenario it sounded really good (and better than the SOTM combination he has tried). He also said that he has “done a brief check with a low power server prototype with no SFP port present running an audiophile Linux variant, and the results are very different”. You have to keep those things in mind. I hope the person who commented earlier that he changed his purchasing decision based on that report has an Extreme server or is planning to buy one. There are other reports that can be found comparing switches with different results in a different context.
I have been playing a lot with my home network recently. As some others have reported, replacing the all-in-one cable modem/router/firewall/etc. box the cable companies in the US provide with a dedicated cable modem and a dedicated router powered by good linear power supplies helps a lot. It makes a bigger difference than my etherREGEN switch.
I know Uptone was engineering the etherREGEN switch to be insusceptible to upstream devices and were thinking that the power supply would probably not matter. That’s what all DAC’s manufacturers would tell you too - it’s an asynchronous signal with galvanic isolation and reclocking, so the upstream device does not matter. Well, probably everyone reading this thread knows better. It is a similar story with the etherREGEN - although they created an excellent product that I like a lot, I found my system even more susceptible to upstream devices than before. The added resolution makes my system more sensitive on upstream network devices so they need good attention too. And powering the etherREGEN with a better than the stock power supply is an obvious improvement.
Back to my home network experiments. Modding the cable modem and routers (i.e. replacing the crappy caps in the power section) also helps. Better DC cables also help. Vibration control helps too.
I was doing an A/B comparison the other day by changing the DC power cable on my cable modem. I had two cables of the same length, materials, geometry and connectors, both broken in. One was shielded and the other one was not. I streamed a Qobuz track, switched the DC cable to my cable modem, and listened to the same track again. You could easily hear the effects of a shield on the DC cable to my cable modem! This was mind blowing. And to be honest, if someone else told me that I would not believe it! I would be like the guy with the white hat from another forum talking about measurements and expectation bias. BUT... I was able to clearly hear the difference from a shield on a DC cable connecting my cable modem.
I played with different routers and WiFi access points. And yes, they sound differently. Using a router without build-in WiFi between the cable modem and the etherREGEN removed a lot of that digital glare. From that experience I feel like the noise generated by the WiFi routers have big contribution to the digital glare. I am using Ubiquiti EdgeRouter X (and the SFP version) routers currently. I like those devices a lot. They have 12V DC input (unlike some of the bigger Ubiquiti devices), so they are easy to power up with LPS. They have a lot of functionality in a really small box with a really simple and nice PCB layout. And they are cheap and easy to configure (if you know what you are doing). For example, it took seconds to create a dedicated VLAN for my server on one of the ports, so my local network broadcast messages would never reach my server. It enables DHCP and routing automatically for you.
My network looks like this at the moment: Cable modem —> Ubiquiti EdgeRouter X SFP —> etherREGEN —> JCAT NIC on my server, all powered by good LPS, cables, etc. Let's ignore the ethernet cables to keep this post more simplified, but I have been playing with a lot of those too. That network set up sounds really good, but I need to add WiFi back. Luckily that router has a SFP port, so I am now playing with various ways of connecting a WiFi access point that is isolated by fiber. I have a second Ubiquiti router, a bunch of media convertors, so there are plenty of options, and I need to find which one works best for my network. A lot of tests ahead of me, but you get the idea of what I am trying to do.
Having said all that, I am curious what the entire upstream network looks like at Emile’s lab. I am also curious if Emile has done any testings with the JCAT Net Femto card in the Extreme. If the Telegartner GOLD M12 switch via copper to the Extreme sounds better than anything else, a logical next step would be to try connecting it to a JCAT NIC. But as we all know Emile is always many steps ahead of us. I was laughing at his comment about the etherREGEN grounding - of course he has tried that and probably every other combination with every switch we can think about
. It's so good to have people like him in the industry.
