Nope. All that shows up in Apps on the TAS home page is Qobuz. I did try a restart of TAS, as well.
If I can find where on my laptop I stashed the latest TAS manual pdf I'll read it and try to figure out what I'm doing wrong. I appreciate your assistance.
Yes I would think after a restart it should be there under apps. Ed or Emile or someone will jump in here, probably in their morning to add what's missing. l can't remember if there was any sequence or restarting. I would reboot the Extreme with two quick clicks with the front button, then start up the app again.
I'm embarrassed to say that I can't find anything other than the Quick Start manuals. Would you happen to have a URL for the location where I can download the current TAS manual?
1
Add mysqueezebox.com details
3
1 Navigate to the „Basic Setting“ dropdown menu
Select [ mysqueezebox.com ]
Enter your credentials you defined at www.myqueezebox.com and choose Save Settings.
Switch to the option „Plugin“ (4). Make sure TIDAL (v2.0) is checked (5).
2
2 3
4 5
Steve, send me your email address via a PM, not sure if Taiko wants it posted. It's for Beta users right now.
I tried sending you a pm with the manual but the file is too large. Send me your email.
Under Server Settings there is an item called "Online Music Library Integration" which has selections for both Qobuz and Tidal. My Qobuz setting is "Integrate online library and automatically check for changes", so I also set my Tidal setting to the same.
However, I've yet to get the Tidal app to show up in Apps on the TAS home page, so I don't know if this will help you, Kris.
Tap the three vertical dots to the far right of the TAS page, tap the downward pointing arrow to the right of Basic Settings to get the drop-down list, scroll down to the fourth item from the bottom, "Online Music Library Integration" and tap on it to open. The top item in the list is, "Online Music Library Integration" with Qobuz and Tidal listed immediately beneath. There are drop down menus for each service from which you can select the active mode of integration (or no integration at all).
FWIW, Roon 1.8 sounded execrable immediately after upgrading. A few hours later I returned and Roon 1.8 sounded like my recollection of 1.7. The 1.8 update seems mostly aimed at re-skinning Roon, so that may explain my perceptions. I should mention that I use Roon with HQPlayer.
