Thank you.Welcome on board
The running comment amongst my audio buddies here, whenever we add a new component… “it better not suck!”
Through 400+ pages of this thread, I am confident it won’t suck!
Keep your rack, just place your Extreme on a single shelf amp platform (or similar) tucked away somewhere on the floor (which is what I do). It doesn't even have to be nearby. All it needs is an internet connection. Four shelf stands which tolerate a 45 kilo load on one shelf are rare, and expensive.Another member of the Extreme community here as I placed my order few days ago
Hearing it on my system was believing, they should place a disclaimer 'don't try this at home' on the thing! A sad moment when it went away, and the countdown to receiving my unit had to commence ...
I have a couple of months to do the preparation work, being the first mandatory thing the replacement of my audio rack which is to small to install this beast.
Any recommendation for a 4 shelves audio stand which does not cost a kidney (still recovering the Extreme financial outlay ) would be appreciated!
Definitely on an isolation platform, the Extreme requires tender loving care (like an isolation platform). There's a reason it's called the Extreme .....
Mighty fine unit.congrats on it.Another member of the Extreme community here as I placed my order few days ago
I spent a lot of time trying to find a rack that allows this. At that time, I was adamant about my Rowland model sixes being on Cerapucs on the floor. The only racks that would allow this were the fake Finite Spider racks that have uprights in one piece rather than the 30cm pieces of the real thing. Big mistake! These fake racks sounded dreadful. After that, I went for Artesania and the improvement was massive. The Artesania Exoteryc rack does actually cost a kidney. However, it's more than wide enough and it is one of the few racks that allows continually adjustable level heights while also supporting the Extreme's weight. A good alternative (but with a different sonic signature and also not inexpensive) would be the Finite Elemente Pagode, but you'll have to go for the Master Reference version as the regular version isn't strong enough. Sorry, I can't think of any affordable racks that I used and would approve of...Thanks for the input, I wish I could to this but in my present layout the available footprint of my audio system is pretty limited
An option following the line you suggest could be to get a rack which allows freeing up the required space underneath it (like the reasonably proiced Norstone Spider, starting from the Spider 3 taller module), and place the Extreme directly on the floor perhaps on an isolation platform ...
Artesania Aire! Not exactly cheap but the Extreme surely deserves it!It makes sense ... which now brings me to finding an isolation platform which does not cost a kidney (I looked into the TAD ZZ series pricelist and almost fainted)
Alternatively, you could look at Artesania's Organic line, the modular floor platform, which is more affordable than the Aire as well as smaller and more manageable, should you want to place it under a rack. And then, of course, there are the Taiko Daiza platforms! I've not heard them yet but given my experiences with Tankwood so far, I have a good feeling about them.
No probs, hope you soon find a good solution!Hi Christiaan, thank you for sharing your experience and for your input!
"A good platform is really worth the trouble and expense" I definitely second that!I started with the E on the floor. Then i got a Entreq Athena with level 3 shelves and boy! did things improve . The E fits but its tight.
A good platform is really worth the trouble and expence .
Greetings Jaxho
Solid Steel (they aren't sold steel BTW) makes strong, reasonably priced racks. I doubt they have any vibration cancelling characteristics. I'm using their four shelf version with a Daiza for my Extreme.Hi Christiaan, thank you for sharing your experience and for your input!
Hello, could you provide some insights on the sonic signature of the Finite Elemente Pagode rack.I spent a lot of time trying to find a rack that allows this. At that time, I was adamant about my Rowland model sixes being on Cerapucs on the floor. The only racks that would allow this were the fake Finite Spider racks that have uprights in one piece rather than the 30cm pieces of the real thing. Big mistake! These fake racks sounded dreadful. After that, I went for Artesania and the improvement was massive. The Artesania Exoteryc rack does actually cost a kidney. However, it's more than wide enough and it is one of the few racks that allows continually adjustable level heights while also supporting the Extreme's weight. A good alternative (but with a different sonic signature and also not inexpensive) would be the Finite Elemente Pagode, but you'll have to go for the Master Reference version as the regular version isn't strong enough. Sorry, I can't think of any affordable racks that I used and would approve of...
