Worth bearing in mind that at least in my system with its Innuos Statement rather than Extreme, the network components are similarly sensitive to vibration as the server and all the other system electronics. I have my entire network installed on vibration isolating/grounding supports and it makes a small but very significant difference in removing elements that generate sonic clues that you’re listening to hi-fi rather than music. Removing those resonance exciting vibrations really does help the sonics sound more natural and organic. It can be the difference between excellent and ‘shivers-down-the -spine’.
Also, I’ve found that using a medical stethoscope is the perfect way to optimize set-up of a rack‘s shelves and any hard-footed devices thereupon. Just make sure you’re VERY gentle in placing the stethescope when its in your ears. With the stethoscope placed on your shelf, gently place a finger on the 2 diagonal corners and try to rock the shelf by alternating pressure. If you hear any sound, you need to adjust the shelf support. Do the same for hard footed devices and see if you can hear any noise when you try to rock the device across its diagonals. For items using 4 rubber feet, slide a very thin strip of paper between front left foot and shelf and while applying enough upward pressure on the same corner to just ’tip’ but not lift the device, slide the paper out, noting the level of resistance. Do the same for the right foot. If the restance is the same, all 4 feet are in good contact with the shelf. If the paper slips out easier on one side, you should shim the diagonally opposing back foot until resistance is equal. You’ll be surprised at the amount of ‘precision’, detail and overall musicality correctly shimming components can achieve. Its not in itself massive but all these things add up and their effect is definitely reflected in the overall enjoyment the system generates and its ‘believability’.
