Some duct tape will cover it all up anyway.I don't think it looks so bad!
Steve Z
I forgot to add one more thing. The sound floor on this is virtually non existent. I did say I was hearing things in the deep bass from songs I’ve played for years and with all this greatness it is uncolored to my ears. Emile says in his recent Masters and Makers Interview that uncolored is his goal. More tomorrowSuperlative SQ observations aside with the new network card and switch, it is starting to sink in (ha, call me slow) how revolutionary and relieving Taiko's full network solution to hi end audio (network card, switch, router alone, not to mention xdms, bps or future pipeline products) will become.
Albeit for Extreme owners primarily, the cost savings and time savings for Extreme owners not having to navigate/additional economic outlay for all the endless permutations of currently available routers/switches/cabling/LPSs/isolation etc and to simply simplify and focus on this path is exalting. Hearing switch user after switch user remove their auxiliary gear is as I think blackmorec put it the ultimate goal. As mentioned earlier, goes without saying folks reaping these benefits are quite fortunate. Amazing to watch/hear this evolution in digital audio on this thread. I am sure more accolades will be pouring in.
Yes, it does.There’s no doubt that the new switch is performing at new sonic quality levels with its supplied power supply. My question is; does it get even better with more expensive power supplies?
It's all about the drugs for some rock stars. . .@oldmustang who used "Fink" to get a feel for the dynamics, I too am a Fink fan and my go to track is "Sort of revolution" as the drug set is spectacular.
Steve, It's beyond hearing the voices, I'm seeing the people from where the voice emanate![]()
So can I assume that since my combo hasn't arrived, when it does, the card will have passed quality control and fit perfectly?So far there are 7 people with a misaligned bracket, I found 3 more amongst the network cards we still have here. This causes the cards to be seated incorrectly which in turn causes a loss of connectivity after a while. We're shipping out replacement brackets.
I am going to try to make the change without moving the Extreme of the Rack (and it is not on the top shelf) which makes the operation complicated, if the card also does not fit well, it can be a "torment"
Please be careful not to get any metal slivers into the PCI slots... It's safest just to bend the clip a bit while waiting for a replacement.I don't expect all people to do it but another option re-drill the hole wider and use a thin washer. Or with a dremel take a little copper off of the lip so the screw aligns...
I'm sure Emile was being tongue-in-cheek
I would cover it with bubble wrap or some other material. Instead of drilling I would use a Dremel with a small grinding wheel attached. You don't need to take very much off. As indicated a thin small washer might be useful...Or just remove the bracket and modify away from the board...While drilling out the hold is an option, please be careful not to get any metal slivers into the PCI slots... It's safest just to bend the clip a bit while waiting for a replacement.
I would have to ask the visitors to indulge me!As mentioned previously, I already have that in my system - and that’s with Roon. When I manage to get my switch installed and access XDMS, I’m expecting Katherine Jenkins to come and sit in my lap.
It’s a good job we have visitors to distract me because not yet being able to install my switch would be frustrating me no end. I’m going to give it a go tomorrow and reports on here are making me wonder just what the hell I’m going to hear next. Looking forward to it anyway.
I knew thatI'm sure Emile was being tongue-in-cheekHe's been quite vocal about liking Roon in combination with the new switch and network card.
100% I would recommend not doing it in situ, for reasons mentioned above. Better to place and evaluate multiple times than to get any junk inside the Extreme. That said, it's possible for a careful person to tape/mask off the area and work.Or just remove the bracket and modify away from the board
This is exactly where my gps is taking me.Steve, It's beyond hearing the voices, I'm seeing the people from where the voice emanate
